Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  1
Thanks Thanks:  1
Results 1 to 2 of 2
Thread: M8 camshaft installation question
    150+ Posts David792's Avatar
    Mar 2019
    Idaho Falls, Idaho, United States
    Default M8 camshaft installation question
    Is it possible to install a cam in a 2018 M8 without clipping the push rods? I'm guessing that the only way is to pull the heads. If I clip the push rods is the function of the new tubes any less efficient that the stock setup?
    2018 Tri Glide Ultra Classic. Vivid Black.
    Quote Originally Posted by David792 View Post
    You have a compound question with some varied answers
    If you are installing a cam compatible with stock ( non adjustable pushrods) you will need to pull the rocker covers and rockers
    If you want adjustables you can cut your old pushrods out and use compatible ( to your cam) adjustable pushrods
    Jims has a new designed pushrod tube set up for M8 engines and tappet blocks designed to make adjustments easier, take a look here
  1. Question re Installation of CB noise suppressors on 2003 Honda GL 1800
    By Kens03red in forum Roadsmith Trikes
    Owners Forum
    Last Post: 02-28-2019, 09:56 PM
  2. Red Shift 468 M8 Camshaft
    By pflatout in forum Harley Tri Glide
    Last Post: 09-14-2018, 09:58 PM
  3. Progressive Shocks / Installation Question
    By 8Crow in forum Harley Tri Glide
    Last Post: 04-19-2017, 06:12 AM
  4. TTS-100 Camshaft - where to buy (Online)
    By Springman2007 in forum Harley Trike Conversions
    Last Post: 04-10-2015, 11:59 AM
  5. GPS/Installation
    By symplysimon in forum Stallion Trikes
    Last Post: 11-04-2008, 06:56 AM
