Likes Likes:  2
Thanks Thanks:  2
Results 1 to 4 of 4
Thread: Twin Cam 88 cam chain pads
    Aug 2020
    Connellsville
    Default Twin Cam 88 cam chain pads
    So I've seen posts About early twin cam 88's cam chain pads wearing prematurely. Does anyone know if they updated them ? I have a 2004 with 23,000 miles that I bought last year with 21,000 miles and figure that they probably haven't been checked.
    Jun 2010
    Indianapolis, In.
    Yes they were updated, 07 all models got the new tensioners.
    06 Street Bob had the new tensioners
    I would suggest gear drive
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    With your mileage you need to check your tensioners for wear for sure
    You also need to check crank run out, this is a big problem on many Twin Cam engines leading to accelerated wear of all internal parts( this is VERY important if you are considering gear drive and ditching the cam tensioners)
    If you don't already have a HD service manual I would get one before attempting any repairs, Good Luck and check back in
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    MIne were worn at 33000 on my 03. Ditched them for a gear drive. Friend had his making a lot of noise & had to replace on a trip. A year or so later they grenaded & had to have motor replaced. After switch to gear put another 70,000 on that 03 without a hiccup.
  1. 2005 88" Cam chain tensioners
    By Lakeman in forum Harley Trike Conversions
    Last Post: 09-29-2017, 05:42 PM
  2. cam chain noise
    By Greenhornet in forum Honda Trikes
    Last Post: 04-01-2017, 07:16 AM
  3. Cam Chain Tension shoes
    By luzierg in forum Harley Trike Conversions
    Last Post: 05-11-2014, 04:55 PM
  4. 06 Twin Cam 120" Build (Lots of Pictures)
    By msocko3 in forum Harley Trike Conversions
    Last Post: 05-26-2013, 06:09 AM
  5. oil scavagesystem on modern twin cam
    By eagle1 in forum Harley Trike Conversions
    Last Post: 09-24-2011, 06:08 AM
