14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  2
Results 1 to 5 of 5
Thread: Air Filter
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Default Air Filter
    Has anyone replaced the air filter with a paper one? If you did, what did you use? I hate the oil one we have on the trike. Thx Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2013
    Hot Arizona, USA
    After looking all over locally, and not finding anything, I found these two on Amazon. I ordered both of them to try.
    Autobahn88 Racing Kit: Stainless Mesh High Flow Air Intake Pod Filter, 2.5inch (64mm) Inlet, Red
    2.50" Inlet 4.50" Wide Red Universal High Dry Flow Cold/Shortram Air Filter Brand: UrMarketOutlet
    Stallion #378
    Suzuki Burgman 650
    Dec 2013
    Hot Arizona, USA
    The filters arrived and I tried both of them. The chrome one fit better, but I installed the red one. I had to modify it slightly by denting the filter so it would fit around one bracket. The original K&N had a hole in it from this bracket. See the pictures. It's a little larger and has an opening in the top also, so it should flow more air. I'm doing a 200 mile breakfast run on Saturday, so I'll see how it fares. Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2013
    Hot Arizona, USA
    Took it on a 249.3 mile breakfast ride this morning. Used 8.7 gallons, I had a little left in the tank when i got back. Lousy gas mileage, but I was doing 80mph getting close to 4000rpm's going up to 5500 feet. Speed limit is 75mph so I really wasn't speeding. I came back a different way, but a lot of that was at 70mph. I'll have to see what it's like on a normal breakfast ride, between 150 and 200 miles up to 4500 feet at 70mph, where I usually average right at 30mpg. What I didn't hear was the intake sucking noise like with the K&N. I like it and it should keep that area around the filter cleaner without the oil from the K&N. Just for info, I only sprayed a very light coat of oil on the filter. Rick
    Stallion #378
    Suzuki Burgman 650
    Jun 2021
    Tacoma, WA, USA
    Quote Originally Posted by rocket1lf View Post
    I'm a newbie (never worked on a Stallion), so, why didn't you go with the chrome one? Also, when you sprayed it, did you spray the outside of it and what kind of oil did you use? Maybe there's a YouTube video :-)
  1. K&N Replacement Air Filter for the OEM Filter.
    Last Post: 12-22-2017, 01:51 PM
  2. Deformed air box, it had a K&N air filter
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 11-10-2017, 11:24 AM
  3. My 1st. air filter change
    By xfootdoc in forum Honda Trikes
    Last Post: 08-01-2011, 02:56 PM
  4. Stock air filter back on....
    By krooozn in forum Honda Trikes
    Last Post: 05-16-2011, 11:58 AM
  5. Oil Overspray into Air Filter
    By PopDukes in forum Harley Trike Conversions
    Last Post: 08-17-2009, 09:35 PM
