14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  1
Results 1 to 11 of 11
Thread: Rear axle shaft
    Jul 2021
    Bremerton, wa
    Default Rear axle shaft
    How can I find out what vehicle the axle shaft used On trike is from?
    Sorry about lack of info. I am helping a friend figure this out and I am a bit slow to figuring out how to use this site on a cell phone that I am not great at using. I know it’s a champion conversion and pretty sure it’s a Honda and he acquired it 2011 but thinks it might be pre 2006. The axle plate where tire attaches has scallop on two sides. The axle housing is offset so axles have different length. This one is close to 25.5” long measured from tire side of plate to end of axle. Would post picture but cannot figure out how
    Quote Originally Posted by Walkers77 View Post
    Bob.. Welcome to Trike Talk..👍👍
    A little more info would be helpful…
    Welcome Bob like Rhino said be nice to know what conversion, year etc.
    Jul 2021
    Bremerton, wa
    Default Edit
    I edited post
    Jul 2021
    Bremerton, wa
    Picture attempt
    Jul 2021
    Bremerton, wa
    Default More picts
    More picts
    Jul 2021
    Bremerton, wa
    Default More info
    1994 Honda 1500 goldwing
    bought champion kit 2011
    was led to believe axle was toyota
    the messed up shaft is on left (when sitting on trike)
    diff marked ACO 201B. The O may have a slash and the 1 may be a 7
    Mark on axle housing 2018
    the scallop on plate seems to be a defining thing
    have been trying to find axle going with the scallop but have only seen one
    But it had 4 scallops instead of 2
    250+ Posts
    Jan 2012
    oz
    I'd contact Champion Trikes and ask them
    https://championtrikesaz.com
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    The Toyota was 6.75 if I remember right.Like early 80s car.Should be able to google some pics.Also should be a tag with one of the bolts in the cover or holding the chunk in.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    Jul 2021
    Bremerton, wa
    Quote Originally Posted by Marc H View Post
    I cannot interpret this
    what is 6.7
    what bolt and cover
    what is a chunk
    200+ Posts
    Dec 2019
    Melbourne Fl USA
    what is 6.7
    what bolt and cover
    what is a chunk
    Hi Walker!
    6.75" is the ring gear size. Often a good way to ID a rearend.
    There are two common styles of rearends: Removable carrier (or 'chunk') and integrated carrier (which has a cover on the back that one removes to look inside)
    There often is tag held on by one of the chunk or cover fasteners. This tag can give valuable information.
    The axle pictures ere great!!
    If you can post more pictures of the rearend, and the trike back end we may be able to help you much more.
    What is the problem with the left axle?
    Purchased Dec 2019 * 2006 Honda VTX 1800 with solid axle Motortrike Conversion. * Color: Y181P Challenger Brown Metallic * Seats: VTX 1800 Big Boy Seat, Passenger Seat, Driver Backrest and Sissy Bar Pad from Ultimate Seats * Exhaust: SUPER quiet hidden pipes, quad 6" baffles, 51mm DB killers
  1. Need DNA rear axle dimension.
    By bobscogin in forum Home Built Trikes
    Last Post: 06-25-2016, 09:38 AM
  2. Solid Axle vs Independent Axle
    By vbbuilt in forum Harley Trike Conversions
    Last Post: 09-15-2014, 11:53 AM
  3. short trikes..4wheeler rear axle assy
    By bj tribble in forum VW Powered Trikes
    Last Post: 11-07-2013, 11:57 AM
  4. Rear Axle Rigid Swingarm or 4 Link?
    By mutwagn in forum Home Built Trikes
    Last Post: 03-19-2013, 09:05 PM
  5. rear wheel track ( Axle widths)
    By sophtayl in forum Harley Trike Conversions
    Last Post: 05-14-2009, 08:39 PM
