ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Results 1 to 5 of 5
Thread: Freewheeler Air Wing luggage rack.
    20+ Posts
    Aug 2017
    Blythewood, SC, USA
    Default Freewheeler Air Wing luggage rack.
    Anyone install Harley's tour-pak rack light kit on your Freewheeler with the Air Wing luggage rack on it? Just tried to install the Harley led light kit on the air wing luggage rack on my freewheeler. Found that the "Y" plug supplied with the kit does not fit a freewheeler. Need to find a work around besides splicing the wires. Maybe different wire plugs??? Thanks
    90+ Posts
    Nov 2019
    Omaha NE
    I got the Custom Dynamics one which I thought was the same as the Harley version and it plugged right in. I thought all touring models to include the Freewheeler had same plugs.
    Turns out the Freewheeler plug apparently is unique to the Freewheeler.
    20+ Posts
    Aug 2017
    Blythewood, SC, USA
    It appears that the freewheeler plug to the rear of the bike is different than that of a tour pak. Not sure about non tour pak models. Looks like I'm going to have to splice the wires. I know now that I should have bought the Custom Dynamics or other unit. Thanks for the reply
    90+ Posts
    Nov 2019
    Omaha NE
    Quote Originally Posted by MGB View Post
    I looked up my CD order and sure enough it appears the light I bought is only for a Freewheeler so the plugs must be unique.
    https://www.customdynamics.com/air-w...it-freewheeler
    20+ Posts
    Aug 2017
    Blythewood, SC, USA
    I ended up splicing the wires. I should have bought Custom Dynamics instead of the harley. BTW, the harley unit is not very bright either.
  1. Freewheeler "Air Wing" lgggage rack.
    By MGB in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-14-2021, 03:46 PM
  2. Freewheeler detachable luggage rack
    By Bryan in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-12-2019, 11:11 AM
  3. air wing rack with led light
    By KevinC1980 in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-26-2017, 02:59 PM
  4. Replies: 9
    Last Post: 08-04-2014, 11:33 AM
