I am replacing rear brakes on 2014 Tri Glide, due to rotors being scored too bad, HOW do you get piston pressed back into caliper ?
Welcome to Trike talk and your first post
The first thing to do is put some slack in the E brake
Next step, remove rear master cover on reservoir, remove some fluid ( as you push the rear pistons in the fluid in the reservoir will rise Next, slowly ( using a C clamp ) push the piston in until it seats ( be careful to not push any further)
Now you can install the pads and reassemble caliper( I like to bleed each wheel as I go along)
Do the same for the other caliper
Once you are done, slowly pump the pistons out and rebleed the system
The last step is to readjust the parking brake
Jack, thanks for your reply on my question, we have Ebrake fully disengaged, but piston will NOT move, no matter how hard we compress C clamp. I know on older models (only ones I could find on "YouTube" , you had to remove a bracket from the Ebrake.......your saying the piston should just slide back into the cylinder pretty much the same as a cars front brakes?
I hope you are making progress?
They have to be turned in clockwise at the same time as being compressed. You can buy the tool or rent/free at an autoparts store. There will be two little indentations on the piston.
https://www.autozone.com/test-scan-a...iece/94798_0_0
2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
with cooler, powder coate tod wheels, Progressive 444 shocks,. More
