Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  12
Thanks Thanks:  3
Results 1 to 14 of 14
Thread: 2021 Freewheeler Clutch Adjustment
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Default 2021 Freewheeler Clutch Adjustment
    I'm feeling like gear changes should be a might smoother on my '21 Freewheeler. This thing shifts like my '59 Panhead when too much oil leaked out and finding neutral can be a chore. I'm also used to having a bit of play in the clutch lever, but this one doesn't seem to have any at all. Is this typical for the new bikes? Last new Harley I bought was a '78 Lowrider and I don't remember this much of a "clunk" going between gears. Don't get me wrong, it runs great and I'm not missing shifts or grinding gears just deciding what's normal and what could be improved upon. I haven't gotten a shop manual for it yet so I'm not up on the clutch lever adjustment procedure or if it even needs it. Has anyone adjusted their clutch on the new cable versions?
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Yup, over on the RS frame down tube you will see the plastic cover over the clutch cable
    Slide it up and out of the way, you will see a red keeper on @ the top of the cable adjuster, push on the fingers to pop the red keeper out. Next push the cable down and reinstall the keeper.
    Now ( on a cold , over night not ridden Trike) remove the derby cover and adjust the clutch basket the same as you would any other Harley. I like 1/2 turn on the adjuster screw.
    After you lock that down, go back to the cable, pop the red keeper back out, the cable should pop back up. Reinstall the red keeper making sure it locks in. You are done, go for a ride
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    softail with the similar set up it shows the red clip
    Have a look here
    1+ Posts
    Aug 2021
    Lewes, Delaware, USA
    I'm a newbie driver, just bought a 2021 Freewheeler. I've only driven 500 local miles. In the past I've ridden as passenger on a Fatboy. I never heard sounds like you described until I got the trike recently. I've noticed the engine runs so hot I feel like my right leg is burning & there are occasional "shifting gear" clunk or metal sounds. I also hear a bit of gas ping at times, but I thought maybe I just got nasty gas when I filled the tank. I am a newbie driver, new to the trike & new to cycling as a driver. So...I am reading & learning, but I am not mechanically experienced, so some of the terminology some posts have is unfamiliar right now. I was starting to think I should get an experienced Harley mechanic just to take my trike for a test ride, make sure all is well. Finding neutral took some getting used to; most times I just need to just toggle with the throttle handle a bit, then find neutral ok, or 2x I had to rock the trike backward & forward, then find neutral ok. Anyway...I'm glad to have found this site. It's good to be able to talk to someone that has the same year & model trike. Let me know how your trike is doing...I'm obviously in the beginning stage of breaking mine in.
    Liz in Delaware
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Quote Originally Posted by LoneDove View Post
    I'm a newbie driver, just bought a 2021 Freewheeler. I've only driven 500 local miles. In the past I've ridden as passenger on a Fatboy. I never heard sounds like you described until I got the trike recently. I've noticed the engine runs so hot I feel like my right leg is burning & there are occasional "shifting gear" clunk or metal sounds. I also hear a bit of gas ping at times, but I thought maybe I just got nasty gas when I filled the tank. I am a newbie driver, new to the trike & new to cycling as a driver. So...I am reading & learning, but I am not mechanically experienced, so some of the terminology some posts have is unfamiliar right now. I was starting to think I should get an experienced Harley mechanic just to take my trike for a test ride, make sure all is well. Finding neutral took some getting used to; most times I just need to just toggle with the throttle handle a bit, then find neutral ok, or 2x I had to rock the trike backward & forward, then find neutral ok. Anyway...I'm glad to have found this site. It's good to be able to talk to someone that has the same year & model trike. Let me know how your trike is doing...I'm obviously in the beginning stage of breaking mine in. Liz in Delaware
    Welcome to the site and congrats on your 2021 Freewheeler purchase. I've been riding two wheelers since I was 16 and that was a looong time ago, but if buying my 2021 Freewheeler taught me anything it's that this is a completely different beast. I love it. As far as the heat situation goes there are several knowledgeable people in here who have some good ideas that could help, but in all honesty I haven't really experienced anything unusual heat wise. I did 200 miles yesterday in every kind of traffic situation in 94 degree weather without a hitch. The Freewheeler has an oil cooler on the front with a forced air fan blowing air on it when needed and the Milwaukee 8 motor was designed with heat mitigation in mind. I wouldn't recommend wearing shorts while riding, but I just haven't noticed anything unusual about the heat issue that would make me think somethings wrong. I'm also beginning to think that the clunk noise when shifting is just a quirk of the bike and getting it into Neutral is about the same as every Harley I've ever ridden. I've had occasion to be around another Freewheeler, a 2017 as it turned out, that sounded exactly the same as mine when he shifted. I haven't yet taken advantage of the tips for adjusting the clutch that have been offered in this thread as I'm coming up on my 1000 mile service and thought I'd mention it to them at that time. If they say anything productive I'll post back in this thread. Good luck, have fun.
  6. #6
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by JTJersey View Post
    Harleys don’t have neutral’ Theres just a little air space between First and Second..And as far as the Harley Clunk that’s a copyright feature and part of its charm 😁.. eliminating it will void the warranty 😁😁..
    2019 Tri-Glide.......
  7. #7
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Harleys don’t have neutral’ Theres just a little air space between First and Second..And as far as the Harley Clunk that’s a copyright feature and part of its charm ��.. eliminating it will void the warranty ����..
    Many years ago I figured out that 90% of the time I had trouble finding neutral I was not actually in first gear when I started looking for it. The other 10% of the time I just needed to move my Harley a little in either direction to find it. I have owned 6 Harleys so this is not just on my Freewheelers, the 2015 I had or the 2020 I now own.
    When you have your 1K service you can request heavier lubricant for your transmission but it will still have the Harley Clunk, just not as clunky. The dealer will also do a test ride after the service. Do not hesitate to ask your dealer about any concerns you have with your new trike.
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
  8. #8
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Haha hahaha 😆. Best way ever to explain it. 👍
  9. #9
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default The dreaded Klunk
    After it warms up in newtrel , I shut down , put in gear , clutch up and start . Noooo Klunk !
    My other issue is the transmission is gears … I use Gear Oil . Not motor oil . My preference, My stubborn way , and I’m sticking to it.
  10. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Liz in Delaware
    Hi Liz and Welcome to Trike Talk
    You may want to take your trike back to your dealer and discuss with a tech your neutral problem, either your clutch is not set up right or too much fluid is in your primary chain case IMO. I have a 21 Freewheeler, the first thing I did was change my primary fluid and adjust my clutch, it is now up to my standards . You will never get rid of the infamous HD clunking of gears, it is nature of the beast. As far as the felt heat you are having, the M8 run too darn hot for their own good. Start reading here, DK Customs is a sponsor here and has tested M8 and Twin Cam engines for some time now
    https://www.dkcustomproducts.com/acl...es-part-ii.htm
  11. #11
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    welcome Liz
  12. #12
    100+ Posts butchvoss's Avatar
    Jul 2013
    patrick SC
    Hi, would you know how high would i go on the tank lift.. I have a 21 freewheeler.. Very good info
    thanks
  13. #13
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by butchvoss View Post
    thanks
    Hi Butch, I used 1 1/2 on my 15 and 17. I have not yet on my 21, tho it will be the same real soon
    You can read more on them here
    https://www.dkcustomproducts.com/gas...ft-kits-c4.htm
  14. #14
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Put Redline with Shockproof in the tranny & you will think someone rebuilt it for you.
  1. freewheeler 2021
    By aussiesteve in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-15-2022, 05:19 PM
  2. Harley Davidson Virtual release 2021 Models 1-19-2021
    By BKtrike in forum General Harley Chat
    Last Post: 10-04-2021, 05:42 PM
  3. Went to try and trade for a 2021 freewheeler
    By stratmarshall in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-02-2021, 11:24 AM
  4. V Trike Cruiser Clutch or clutch adjustment?
    By KeithK in forum Roadsmith Trikes
    Owners Forum
    Last Post: 03-25-2019, 12:23 PM
  5. Clutch Adjustment
    By rblackcar in forum Harley Trike Conversions
    Last Post: 03-05-2016, 05:49 PM
