Likes Likes:  5
Thanks Thanks:  2
Results 1 to 6 of 6
Thread: Roadsmith 2017 CV boot replacement
    Aug 2021
    Glendale heights, illinois, USA
    Default Roadsmith 2017 CV boot replacement
    I have a 2017 Roadsmith on a 2003 Goldwing
    CvV boots are torn
    Can’t get the axle nuts loose.
    Using 36mm socket and 3/4” breaker bar
    And extra leverage. Also tried electrical impact gun.
    I have the cotter pin removed already
    And the brake caliper is off.
    I have done many trucks and cars
    Never ran into one this tight before.
    Any advice is most appreciated
    Thanks Jim
  2. Roadsmith banner
  3. #2
    Quote Originally Posted by jbrauer View Post
    CvV boots are torn
    Thanks Jim
    Jim.......Welcome To Trike Talk.........Have you tried applying heat to the nuts..??
    I know this sounds crazy, Any chance the nuts are left handed threads ?
  4. #3
    Founder: Roadsmith Trikes
    TrikeTalk Sponsor
    May 2016
    Daytona Beach Fl
    Default MrTrike
    I have no idea why you want to take the axle nut off. All you have to do is remove the axle with the 2 cv joints on it. Then remove c-clip from end off damaged axle. Now slide cv-joint off axle and replace boot. If sand or water got inside cv joint, then wash entire joint and repack it with moly cv joint grease. replace joint and c-clip, then reinstall axle. make sure you torque the 6 bolts. I would say to put a dab of blue locktite on the treads before installing bolts. Good Luck Dick
  5. #4
    Cut N Shoot Customs
    Cut N Shoot Customs's Avatar
    Feb 2016
    Conroe
    CvV boots are torn
    Thanks Jim
    Welcome Jim,
    Mr Trike is the founder of Roadsmith Trikes and knows them like the back of his hand because he is who has designed and manufactured the entire Roadsmith product line for the last 42 years. As he said, it is not necessary to remove the axle nuts in order to change the CV boots, just unbolt and remove the axles.
    The joints are Volkswagen-based, and are "flat-sided" joints that make changing a boot a pretty simple job. Just be sure to use grease designed for CV joints - regular ole moly-b can cause havoc with the boots.
    Boot part number: 113-501-149
    CV joint part number: 113-501-331
    If you need more tech support, instructions or parts support, call Mike or Doug at Roadsmith Trikes
    at 1-800-331-0705.
    Randy
    Visit Cut N Shoot Customs Website
    Visit Cut N Shoot Customs Trike Shop on Facebook
    New and Used Trike Sales - 16 Years In Business
    Trike Conversion Sales & Installation - Factory Trained & Certified
    California Sidecar - Roadsmith - Hannigan - Motor Trike - Frankenstein
    Conroe, Texas - Call (346) 800-7946
  6. #5
    Sep 2016
    Springfield, Mass. USA
    Mr trike (Dick)
    Thank you for coming on and helping other's with R/S problems..
    I want you too know that your the reason that I went Roadsmith, model, instead of any of the other brand names.............Cause you always come on and help..
    Thank you again, and again!!
    (third season with R/Smith now, and happy as a clam..........)
    Sep 2012
    Lakeland, FL
    I met Mr Trike (Dick Lindholm) back in the day when the first 'Trike Shop' was on Beach St. A super nice guy that definitely knows 'Road Smith', and was always anxious to chat 'Road Smith' when he was in his tiny office. Thanks Dick.
  1. Boot Marks on Chome Heat Shields and Exhaust Pipes
    By TonkaDriver in forum Harley Tri Glide
    Last Post: 04-27-2018, 12:10 PM
  2. Boot Guards/Heel Guards Rider Floorboard
    By Amputee55 in forum Harley Tri Glide
    Last Post: 08-03-2016, 11:44 AM
  3. melting my boot heel on rear exhaust pipe
    By bowelder in forum Harley Tri Glide
    Last Post: 04-24-2016, 11:16 AM
  4. Cruiserworks boot problem
    By MangoMike in forum General Discussion
    Last Post: 01-06-2014, 04:30 PM
Tags for this Thread
