BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  6
Results 1 to 12 of 12
Thread: Won’t start in gear
    150+ Posts
    May 2016
    oberlin
    Default Won’t start in gear
    I know it’s almost always replace the left hand switch. Has anyone ever been able to repair existing switch. If I read correctly the replacement housing has a stronger spring. Mine is intermittent and mainly when hot. Always hated replacing parts if cleaning or modify original is possible. Or is the unit not really user serviceable. I also understand that cruise shouldn’t work when switch bad. Never a issue with cruise.
    2016 Tri Glide and 2012 FLHTP
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by ctdair View Post
    You probably know this already.......But..
    Are you sure the cluch lever is all the way on the grip...And you are on the brake hard..
    2019 Tri-Glide.......
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Remove the clutch lever, look inside the perch, you will see the switch. Clean the area face of the switch with brake clean or alcohol. Work the switch a couple times with your finger.
    Reinstall the lever and try to start in gear. This is all I ever had to do to my 17 M8, I never did have to replace the switch in 28 k miles
    Good luck
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    What he said ^^
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    You have a 2016 model. THat was NOT recalled for the clutch slave cylinder problem tho IMO it should have been
    It is possible your clutch is not releasing fully for the clutch switch to fully engage IMO
    Have you ever flushed your clutch fluid ? If the answer is no, do it now. It needs to be done every 2 years. This may also help your no start when hot
  6. DKCustoms postbit
  7. #6
    150+ Posts
    May 2016
    oberlin
    Alright all good suggestions. Yes on the lever and brake. No I haven’t flushed the clutch or brakes. Will do that ASAP
    I could see binding on either of those systems being the culprit. Will also look at the switch and housing. Thanks and I’ll report back as time allows.
  8. #7
    5+ Posts
    Jan 2021
    Muskegon, MI, Muskegon
    Default Won't start in gear
    I have a '15 tri-glide and never could get it to start in gear like I could my Road King. Then someone told me the difference with the trike. With a Tri_glide to start in gear, you must not only hold in the clutch, but also either use the foot brake or front brake at the same time. Should start in gear everytime if you do both. It has started for me every time since I learned this. Many dealers don't seem to know about this either. I actually found the directions in my owner's manual after I was told the solution. Hope this helps.
  9. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by OLDYELR View Post
    Good info Jack, if one does not have an owners manual you can look here
    https://serviceinfo.harley-davidson....cle/lookupForm
  10. #9
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    On my 17 the left switch pack went bad, but it would die when pulling up to a stop sign or stop light. It would start in gear though, if you are running thicker than stock grips this could be a issue.
  11. #10
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Not sure what model years involved but my 2018 was. Replaced switch pak once with same oem part and it too failed. Later a new revised switch pak was released and it included a new clutch lever to better actuate the switch. I suggest you check with dealer. Might be covered by moco.
  12. #11
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Mykneesbehurtin View Post
    On my 17 Triglide I had an adjustable Clutch lever It went from 1 to 8 if I put it on one the closest position to the lever it wouldn’t start… it’s a very fine distance to the contact switch..
  13. #12
    50+ Posts
    Apr 2018
    Ogden, Utah, USA
    Default Starting in Gear
    One other idea. If you have changed your grips to a larger circumference the lever may not go back far enough to activate the switch. I had this happen to me.
  1. Trike won't start in gear with parking brake on
    By bowelder in forum Harley Tri Glide
    Last Post: 12-03-2016, 09:37 PM
  2. Trike won't start
    By rwhgme in forum Harley Trike Conversions
    Last Post: 11-05-2012, 02:53 PM
  3. Trike Won't Start??
    By BinIdaho in forum Harley Tri Glide
    Last Post: 09-08-2012, 11:17 AM
  4. Trike won't start
    By clo in forum Honda Trikes
    Last Post: 08-14-2012, 08:25 PM
  5. Won't start?
    By Big Dog in forum Stallion Trikes
    Last Post: 10-05-2009, 07:48 PM
