Likes Likes:  49
Thanks Thanks:  13
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 46
Thread: What could it be?
  1. #21
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    I too like most people who have a battery in a vehicle have a battery story. Had a battery on my Stallion go bad. My trike is a daily driver and went to ride to work one morning and it was totally dead. No power at all. Put it on charge for the day and it took charge and tested good so I rode it for about a week with no issues. I just thought I’d left the lights on and all was good. Riding every day and one morning I started it, backed out of garage and washed it. When I tried to start it bout 1 1/2 hrs later the battery was dead again. Removed left tire and removed battery took it to auto zone. It wouldn’t take charge. Purchased replacement and 2 yrs later l sold Stallion with no more battery issues.
  2. #22
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    Your just overthinking the stituation. Go back to diagnostic basics.
    2021 Tri Glide in Billiard Red
  3. #23
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by GTK View Post
    I couldn't agree more, tho looking back @ the OP posts he states he has already determined the problem and fixed it
    It will be interesting to see what the fix was
  4. #24
    Oct 2010
    He can’t test a battery without a voltmeter but he’s determined the ignition switch and wiring harness is the problem without the use of a voltmeter. But maybe I’m missing something in his posts. Sometimes I can’t even make sense of my own posting.
  5. #25
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    I must of missed that post or missed understood it??........Which number post on this thread was it....
    2019 Tri-Glide.......
  6. #26
    Oct 2010
    He can’t test a battery because he doesn’t have a voltmeter but he’s determined the ignition switch and wiring harness is the problem without a voltmeter. But maybe I’m missing something in his posts. Sometimes I can’t even make sense of my own posting.
  7. #27
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Bob, read his post #10
    Maybe it is just me, but I dunno what he is talking about thru this whole thread. He obviously is not using basic diagnostic skills?
    Me, I would have first done an on board scan followed with a load test of the battery
  8. #28
    Jun 2008
    Lovington, NM, U.S.A.
    Seems like one of the comedy acts that comes to a GW forum with a similar issue. No one checks the battery they just assume its good.
    1. A battery must be good to begin with.
    2. If suspect it must be charged and tested
    3. If you do not have a spare, use the one in a non-running car/truck with jumper cables.
    4. Always check connections.
    5. The engine will start when the ECM senses the proper voltage to fire the ignition system, if it doesn't sense proper voltage the starter will spin.
    6. If you hear click-click and nothing happens, you need a new battery. Doesn't matter how new it is, I had one fail a week later as it had a bad cell.
    Modern motorcycles with more complex electrical system where each sensor must receive proper voltage. I can say one other thing and that is I am happy to be retired and do not have to work on this new stuff.
    Retired trike builder
  9. #29
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    My New York/Brooklyn skepticism makes me think we’re going on a ride to nowhere..🤔..
  10. #30
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Take this from a guy that made a living testing batteries for the Navy for over 20 years.
    You do have a short, when a cell in a battery fails the plates in that cell all short together effectively making 1 cell of the 6 useless.
    This will cause all the symptoms that you are getting.
    I have had a cell short and shut down all electrical power in a SUV while running 80 MPH in heavy traffic.
    Not a fun situation.
    A load test will verify this.
    The only way to fix it is to replace the battery.
    My 2 cents.
    Bob
  11. #31
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by hardwickbv View Post
    My 2 cents.
    Bob
    IMO, it is too bad so many batteries are sealed now days
    In the past it was fairly common to be able to test individual cells and see right away you had a problem
    A Hydrometer test to check each cell, We also used a Sun Machine battery test station to check dead shorted cells, this took all of the guess work out of the equation
  12. #32
    Oct 2010
    I think we’re spitting in the wind.
  13. #33
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Yea but on the plus side they now last twice as long, the bigger issue is when they decide to go bad it is with no warning.
    You go out in the morning after riding or driving home the day before with no problems an then no joy.
    Lithium has is benefits but I've seen some testing on them in the earlier days that would make your head spin.
    Can't bring myself to put one under my seat due to what I've seen.
    Part of our job was to see how well they would work under normal conditions and in some cases see what it would take to make them rapidly deflagrate. (google it)
    Bob
  14. #34
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Bob
    Those batteries started 55 fires 🔥 and a few deaths in New York City when charging scooter batteries….And there’s the Chevy Volt fiasco! 🔥🔥
  15. #35
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    I love the sealed batteries….no more jerking the side panel to see if it has adequate water.
  16. #36
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by paws View Post
    I do miss the odor of sulfur when the voltage regulator over chargers...And the theres the hydrogen gas.....That can and will go boom!....I blew one up when i was charging it and the alligator clip caused a spark ....Battery acid and lead plates all over the engine bay.......
  17. #37
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    If you ever hear a hissing or whistling sound from a battery, it is about to blow
  18. #38
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Now you tell me..........Where were you in 1968.....
  19. #39
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Jump starting a L J Mack Diesel when the group 4 Batteries blew their tops off
  20. #40
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Do you remember Abercrombie & Fitch.......The Real Abercrombie & Finch, I was wearing a jacket that i bought from them from their Madison Ave Manhattan Store....Needless to say the battery acid destroyed it...Luckily for me as the battery popped i was looking the other way, Or it probably would have blinded me...
  1. What could cause this problem?
    By trikermary in forum Harley Trike Conversions
    Last Post: 12-18-2012, 09:36 AM
  2. "RIDE", just in case You could make it....
    By skuuter in forum General Discussion
    Last Post: 04-20-2011, 07:59 PM
  3. think I could
    By John Luciano in forum General Discussion
    Last Post: 04-06-2011, 12:47 AM
  4. Harley-Davidson could be leaving Milwaukee?
    By ThirdWheel in forum Harley Trike Conversions
    Last Post: 09-13-2010, 06:04 AM
Tags for this Thread
