Results 1 to 4 of 4
Thread: Soft brake pedal
    Sep 2021
    Merthyr Tydfil
    Default Soft brake pedal
    Hi all. New to the forum. I have a goldwing 1500 trike with a suzuki vitara rear axle. I have adjusted the drum brakes and bled the system but the foot pedal only gives a bit at the very bottom and it will not pass our highway inspection. Any ideas pls
    welcome mark
    question. is the trike new to you or did this develop while you have owned it?
    Welcome to Trike Talk
    What happens if you pump up the brakes, does the pedal change any?
    Have you had any recent brake work done other than what you have posted?
    Are you having to add fluid?
    Feb 2022
    Chandler, IN
    Default soft rear brake on GL1500
    I bought a 1999 GL1500 last September with a 2001 Tri-King conversion. The rear brake was basically useless. I read on the GoldWing forum that you need to bleed the FRONT LEFT caliper first, then bleed the left rear then right rear. This is because the front left disc is tied to the rear brake. It worked for me. I had tried just bleeding the rear first with no luck BTW.
    hope this helps.
  1. brake pedal disengaed
    By MathRetired in forum Stallion Trikes
    Last Post: 08-24-2012, 03:40 PM
  2. Over size brake pedal
    By felixpirozzi in forum Honda Trikes
    Last Post: 12-08-2011, 09:54 AM
  3. Brake Pedal Extension
    By rmrc51 in forum Honda Trikes
    Last Post: 10-11-2010, 12:44 PM
  4. Stallion brake pedal.
    By DEIC in forum Stallion Trikes
    Last Post: 11-13-2009, 07:34 PM
  5. moving a brake pedal plus other
    By acmeactor in forum General Discussion
    Last Post: 11-05-2009, 04:55 PM
