Speed Bleeders
Likes Likes:  10
Thanks Thanks:  2
Results 1 to 17 of 17
Thread: Battery Tending Pigtail
    250+ Posts dawingrider's Avatar
    Dec 2014
    Titus, AL
    Default Battery Tending Pigtail
    Going over my '21 TG to get familiar with it and located the battery tending pigtail behind the left side panel. The connection is not standard to what I'm used to. There is a blade terminal connection; anyone know what it is for?
    Name:  Charging Pigtail.jpg
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by dawingrider View Post
    Got my curiosity peaked .....Thats new to me also....?...Hopefully someone will chime in with the info...
    2019 Tri-Glide.......
    40+ Posts
    May 2021
    Clatskanie, OR
    From the HD website
    5 Amp Global Battery Charger
    The 5 Amp Global Battery Charger incorporates all the features of the 1.5 Amp Global Charger, and reduces typical recharging time to 1 to 2 hours. Maximum output charge rate is 5.0 Amperes. Compatible with 2-pin and 3-pin charging harnesses, the output current automatically switches between 5A and 2.5A, depending upon the type of harness used. The full 5A output current is available when used with 3-pin type harnesses and 2-pin charging harnesses are limited to 2.5A. The advanced solid-state circuitry constantly monitors and adjusts the voltage to maintain optimum battery energy levels without overcharging and automatically switches to float mode for maintaining charge over extended periods of time. The charger accepts worldwide input voltage 100 to 240 VAC @ 50 to 60 Hz. A universal power supply unit enables the 5 Amp Global Battery Charger to properly charge and maintain all H-D® 12-volt batteries worldwide. 2 year manufacturers warranty. Typical Recharge Time: 1-2 Hours.
    99869-04
    BTW…not sold in the US to my knowledge..
    NRA-Certified Instructor/CRSO
    FAA Part 61/107 Pilot
    2021 FLHTCUTG
    2009 BMW R1200RT
    Dec 2014
    Titus, AL
    Thanks Gregg! Guess if I ever take a trip to Europe...
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Did the dealer give you the charger that plugs into that harness..?..
  6. DKCustoms postbit
  7. #6
    40+ Posts
    May 2021
    Clatskanie, OR
    Hahaha…won’t happen.
    Any standard SAE plug like this (standard) fits/works with that socket…I have the same 3-point socket on my ‘21 TG…
    NOTE: this is the BIKE side polarity; note the + connection is shrouded/protected.
    The charger side is opposite…as battery maintainers have short-circuit protection.
    2021 FLHTCUTG
    2009 BMW R1200RT
  8. #7
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Guess H-D is standardizing parts so they don't have to have 2 - 1 for US and 1 for international.
  9. #8
    40+ Posts
    May 2021
    Clatskanie, OR
    I would have a tendency to agree with that; the bike battery tender harness is actually part of the main wiring harness now, not an add-on.
    2021 FLHTCUTG
    2009 BMW R1200RT
  10. #9
    Dec 2014
    Titus, AL
    No they didn't. However, I did find out if I rate them a "10" on a survey they would give me a charger . The trickle charger I have plugs into the standard 2 pin terminals without issue. I measured the voltage at 12.74 so I won't know if it's actually charging until the voltage actually drops enough to kick it on (if that makes any sense).
  11. #10
    20+ Posts jetspeed8's Avatar
    May 2021
    Mims, FL
    I was told by HD parts guy that it is used if you are charging a lithium battery.
    2021 CVO Tri-Glide
  12. #11
    Dec 2014
    Titus, AL
    Quote Originally Posted by jetspeed8 View Post
    That's Interesting. Then they should sell/provide an adapter for chargers to accommodate that setup. Haven't seen them available in the catalog. The 800 mA charger is the only one they sell that supports lithium batteries.
  13. #12
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Sometimes when the expert (Parts Guy)… doesn’t know the answer they tend to say anything to move you away from the counter…Not saying that’s the case in this instance but it wouldn’t surprise me..🤔
  14. #13
    200+ Posts
    NC Triker's Avatar
    Jul 2012
    Supply, NC
    If you give them a 10 rating they will send you a free charger. Is that bribe???
  15. #14
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by NC Triker View Post
    Is the Pope Catholic..😱
  16. #15
    Dec 2014
    Titus, AL
    More than likely it is a possibility
  17. DKCustoms postbit
  18. #16
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Never trust the parts guy..
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  19. #17
    Dec 2014
    Titus, AL
    Well what-da-ya know, I gave them a "10" and they gave me a free charger!
    I like "free" especially since I did give them 35K
  1. Old Battery vs New Battery
    By Baldy_54 in forum Honda Trikes
    Last Post: 12-05-2023, 10:15 AM
  2. Battery Access Modification
    By symplysimon in forum Stallion Trikes
    Last Post: 09-02-2021, 08:26 PM
  3. Battery life and battery purchase
    By pcombe in forum Harley Trike Conversions
    Last Post: 02-21-2019, 05:53 PM
  4. When to change battery?
    By North of 49 in forum General Discussion
    Last Post: 07-04-2008, 12:18 PM
  5. Gel Battery
    By docb in forum General Discussion
    Last Post: 03-17-2008, 02:44 PM
