Likes Likes:  4
Thanks Thanks:  3
Results 1 to 12 of 12
Thread: Turning Traction Control Off
    Default Turning Traction Control Off
    Here you will learn how to turn traction control off
    https://serviceinfo.harley-davidson....n_US?nid=29601
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Here you will learn how to turn traction control off https://serviceinfo.harley-davidson....n_US?nid=29601
    After looking the article over I'm still confused about how to best utilize traction control. If it does, in fact, keep your tires from slipping why would I want to turn it off on loose sand or uphill on wet grass? I'm asking because the driveway to a relatives house starts as a rather steep incline made of gravel. Should I turn traction control OFF or leave it ON? I'm hoping to be down there this weekend and I'll have to deal with this driveway entrance.
    Quote Originally Posted by JTJersey View Post
    The traction control is more of a safety net for wet road traction, I have left mine on on my 21 Freewheeler. If it becomes any kind of a problem for me I can always turn it off
    Very simple.......Try going up with it on and see what happens.....My driveway is very steep, And when its snow coved i turn it off because as the wheels start spinning/slipping the engine will bog down 'Almost like limp mode...
    Read your owner's manual, it sounds like you are comparing traction control to limited slip rear ends, not the intended purpose for it IMO
    Traction control applies the brake[s].....Limited slip..AKA Posi allows both rear wheels to spin at the same speed...
    Exactly
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    This brings up a question that occurred to me recently. Are both rear wheels powered on the Freewheeler or just one, if so which one?
    Normally both...But in low traction conditions.. IE; On Ice the one with the least traction..
    Mona Lisa Vito splaned it... [My Cousin Vinny]
    80+ Posts
    Aug 2016
    sebastian FL
    Yes I believe The FLRT has a completely open diff (no limited slip)
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    So I had no problem going up the driveway in VA I mentioned previously, bumpier than hell, but got up it without turning off traction control. Going down was no problem and I went up and down a couple times while there. Guess I'll just leave traction control alone.
  1. Turning Traction Control Off
    By Jack Klarich in forum Harley Tri Glide
    Last Post: 09-18-2021, 12:29 PM
  2. Safety Recall 2019-2020 Trike - Traction Control
    By Koolbreeze in forum Harley Tri Glide
    Last Post: 02-24-2020, 05:48 PM
  3. 2019 Tri Glide Traction Control System works amazingly well
    By DK Custom Products in forum Harley Tri Glide
    Last Post: 06-05-2019, 12:40 AM
  4. Traction Control Brake
    By hARLEY jOE in forum Harley Trike Conversions
    Last Post: 03-11-2013, 04:35 PM
  5. Traction Control Braking
    By Greydog in forum General Discussion
    Last Post: 12-23-2009, 07:53 PM
