SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Likes Likes:  9
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: LED Brake Lights - Inexspensive
    100+ Posts W3JNP's Avatar
    Nov 2016
    Reading, PA
    Default LED Brake Lights - Inexspensive
    I wanted to add a Custom Dynamics TKE Brake Light Flasher to my Freewheeler but the folks there said I would need to have LED brake lights installed as their flasher cannot handle the load from the stock bulbs and will burn out quickly.
    https://www.customdynamics.com/magic...idson-triglide
    I started pricing LED brake lights and decided to look for a less expensive approach.
    I found that the Sylvania Zevo 3157R Red LED Super Bright’s are direct plug and play replacements for the stock bulb.
    These can be found at Wal-Mart or online for around $12.00 for a pair.
    People who know a lot more about these things than I do recommend using red LED’s as they show up brighter thru a red lens than if I using white LED’s.
    NOTE – These LED bulbs are polarity sensitive so I suggest if you buy them you test them before putting the brake light lens cover back on. If it does not work turn the power back off and reverse it in the socket.
    I was also told that it is best to leave them on for a minute or two so that the ECM learns that the lower current draw is not a burned out bulb and then causes a hyper flash and error code.
    I did this and have had no problems.
    These work very well and appear a bit brighter than the stock bulbs were.
    The brake light flasher is on order and is a simple plug and play installation.
    2008 Stallion
    Reading, PA 19606
    Quote Originally Posted by W3JNP View Post
    I have run those light bulbs on 3 Freewheelers and like them a lot
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    Those are the ones I run on the rear of my Tri-Glide...
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Jack, did you have a "fast flash" with the turn signals ?? TIA
    I ran my 4 ways for a minute and checked for codes, good to go
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Thanks Jack. Been shopping & none of the Wally Worlds near us (4) have them. would have to order . Now $18 -$20
    Going to keep checking other places for in stock purchase.
    Check Orileys and Advance Auto, they carry them in stock most of the time
    The hyper flash is normal until the BCM sees the correction you make by using the 4 way flashers for a minute or 2, then check for codes and clear any you have
    The codes ( if detected will not come back) after clearing as your BCM now recognises the new bulbs and the difference in the voltage and amperage of the LED bulbs
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Got them ordered from WallyWorld. 2 sets so I have spares. Got the Custom Dynamics flasher module for the Brake lites & also the one for the Tour Pack lites. Been an expensive day LOL. O well can't take it with me. Thanks for all the info.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    So the bulbs I ordered from Wally World, been on order since last week won't be here till next Tues. ordered the 2nd to b delivered the 14th. WW is right on the Ball lol. Parts from Custom Dynamics arrived in 3 days. No one in my area had the bulbs. Hope I never have to order from WW again. Hell i have had stuff from Ca in 5 days WW stuff is coming from Tx in 14 days
    Damn Wally World does not stock them here either, I went to Oriellys, I have a contact there that gives me discounts
    One good thing there is if they do not have them in stock they can get them from their warehouse in the afternoon
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    O Reillys price almost double $24.99 Blister Pack of 2
  1. ***Stealth LED Run-Brake-Turn Lights- True Plug-n-Play Sportster***
    By DK Custom Products in forum DK Custom Products
    Last Post: 07-01-2019, 11:49 AM
  2. Replies: 4
    Last Post: 04-17-2018, 10:01 AM
  3. ***DK Custom Products Universal Fitment - Stealth LED Run-Brake-Turn Lights***
    Last Post: 06-27-2017, 11:43 AM
  4. Replies: 2
    Last Post: 02-03-2017, 12:27 PM
  5. Which LED lights for the rear tail/brake lights
    By 470004 in forum Harley Trike Conversions
    Last Post: 11-20-2014, 08:13 PM
