Likes Likes:  4
Results 1 to 7 of 7
Thread: Drive Sprocket Replacement
    Oct 2021
    Daleville, AL, US
    Default Drive Sprocket Replacement
    I have a 2007 Harley Street Glide with Champion Independent Suspension conversion kit. The kit has over 30k since install. The drive sprocket teeth feel like shark teeth and belt jumps teeth when romp on throttle. I need a new sprocket
    250+ Posts
    Jan 2012
    oz
    You posted in the California Side Car trike forum
    Quote Originally Posted by Greywolf View Post
    Ron, Are you asking where you can you find a sprocket....Also you'll need a new chain!
    Oct 2021
    Daleville, AL, US
    I need a new sprocket.
    Since I have over 30 k on kit I must replace drive belt
    Ron is the belt adjusted correctly? If it to loose it can jump. Bottom run of the belt in about the middle should only be able to push it up about 1/2 a inch with about 10 lbs of pressure. How many miles on the belt? Should be the same belt as before the conversion.
    Oct 2021
    Daleville, AL, US
    Belt tension is correct.
    The sprocket teeth should have a dome shape on top for the drive belt to fit into and grip the belt. My sprocket's teeth are pointed which allows the belt to slip if you romp on the throttle.
    Per Champion recommendations, I installed a new belt when the kit was installed. The new belt now has over 30k miles.
    Cut N Shoot Customs
    Cut N Shoot Customs's Avatar
    Feb 2016
    Conroe
    Ron, call Mark at Champion Trikes of Arizona at 480-597-3444. He should be able to help you with parts.
    Visit Cut N Shoot Customs Website
    Visit Cut N Shoot Customs Trike Shop on Facebook
    New and Used Trike Sales - 16 Years In Business
    Trike Conversion Sales & Installation - Factory Trained & Certified
    California Sidecar - Roadsmith - Hannigan - Motor Trike - Frankenstein
    Conroe, Texas - Call (346) 800-7946
  1. Cams, chain drive vs gear drive
    By molokaimike in forum Harley Tri Glide
    Last Post: 03-25-2021, 04:16 PM
  2. Replies: 34
    Last Post: 02-13-2020, 12:04 AM
  3. Drive belt replacement
    By Doctor Doug in forum Harley Trike Conversions
    Last Post: 08-01-2019, 05:41 PM
  4. Replacement drive belt
    By RoadKingTrike in forum Harley Trike Conversions
    Last Post: 01-03-2018, 06:42 PM
  5. Time for Drive Shaft and U-Joints Replacement?
    By kenwantz in forum Honda Trikes
    Last Post: 04-21-2017, 07:26 AM
