BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  19
Thanks Thanks:  3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 48 of 48
Thread: Thinking of Changing the Factory Aircleaner
  1. #41
    10+ Posts Crocsr's Avatar
    May 2021
    Seneca SC USA
    [QUOTE=Jack Klarich;868041]
    Quote Originally Posted by Crocsr View Post
    This will void your factory power train warranty, if you are OK with that
    Check with Kevin @ DK Customs on pricing for a Power Vision tuner, IMO it hands down is the best out therehttps://www.dkcustomproducts.com/pow...s-c120-259.htm
    Jack; Thanks for your reply. I'm aware of the warranty issue, and won't do that. I understand that purchasing the HD tuner is acceptable. Have you experience removing the catalytic converter?
  2. #42
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    [QUOTE=Crocsr;868130]
    I have not done any, but you can read here
    https://www.triketalk.com/forum/thre...oval-Questions
    You can find decatted pipes on E Bay for a good price
  3. #43
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    [QUOTE=Crocsr;868024]
    If you want real bang for your buck check out D K Customs for an Outlaw ACAnd yes HD can and will eat up your warranty on any M8 engine for AC and exhaust and tuners not approved by them and the EPA policeThe EPA has hit them hard ( HD agreed with the EPA ) over this baloney
    Hey y'all, I purchased a 2021 Freewheeler last year, and would like to improve the sound a bit. I'm under the impression that removing the catalytic converter will improve performance and reduce heat, so I plan to cut the Y pipe, remove the cat, and reweld. Then purchase better mufflers, and now maybe the air filter system you installed, (I like it). I'm told doing all this will also require me to change the "tuner", and that requires calibration??(who does that)? I would sure like advice from you guys about my plan. Thanks
    Croc
    John, when you make your changes check Jim Palmer for the extended warranties he sells if you want to protect your ride
    Harley has allowed the EPA to impose such stupid regulations, even decatting the head pipes and using a non approved air cleaner will void your factory warranty
    I think HD entered this agreement seeing dollar signs knowing they could beat the warranty on modified bikes and make up for their losses by imposing the use only our parts or else
    Check here with Jim Palmer, he is very easy to work with and honest
    https://www.motorcycleagent.com/contact
  4. #44
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Removing a Catalytic Converter is a Federal Offense...IE....Tampering with an Emission Control Device....Harley didn't make the law...They just got caught looking the other way.
    2019 Tri-Glide.......
  5. #45
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Good point, also the air cleaner is considered a violation now, not only because of air quality standards but it also can violate noise standards
  6. #46
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    OP can change a catch can back to stock breathing in about 10 minutes if warranty work is needed
    According to HD even changing to a non approved air cleaner can void warranty, that said skirting an EPA mandate on pollution control ( could mean air cleaner and for sure the head breathers) would bring bad JUJU when seeking warranty work
    What would happen if I just took off the vent hoses entirely? No catch can, no routing anywhere. Let it vent into the air cleaner cover.
  7. #47
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by JTJersey View Post
    Probably gona make a big mess on the filter, it will eventually ruin the filter from saturation
  8. #48
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    If it ever gets above 30 maybe I'll pull the air cleaner cover off. Might be enough room inside for a catch can.
  1. thinking about changing to real three wheeler
    By papadon in forum Outrigger Style Trikes
    Last Post: 05-08-2015, 02:22 PM
  2. changing antifreeze
    By newtriker in forum Honda Trikes
    Last Post: 05-21-2013, 06:37 AM
  3. Rear Tire Changing
    By firebreath in forum Honda Trikes
    Last Post: 11-09-2009, 04:00 PM
  4. changing o rings in front forks
    By newtriker in forum General Discussion
    Last Post: 02-22-2009, 02:49 PM
  5. Changing filters
    By Ozarkryder in forum Honda Trikes
    Last Post: 02-26-2008, 05:49 PM
