Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Likes Likes:  11
Results 1 to 13 of 13
Thread: reverse not working
    30+ Posts
    Sep 2021
    lake wales fl. USA
    Default reverse not working
    So the dilemma is that I have power to all the circuit's. Tested the motor on bench and all worked. Reading 12 volt through the circuit breaker and relay all read's good. So It will not go into revers. Any one have had this problem would appreciate the solution you derived at. Thanks for any info. I am at a loss. Will check my ground wire today. Russ.
    Quote Originally Posted by Old Hippie View Post
    Pull out the motor..[Two bolts]..And check the brushes' Dollars to donuts they are Worn/Stuck or Corroded .......
    30+ Posts
    Sep 2021
    lake wales fl. USA
    Thumbs up
    Had it off yester day and it worked fine on the bench. Like I said getting power thorough the circuit's. Thinking now might be a bad or week ground. Thanks for the info rhino. It dose not make since it would work on the bench and not in the bike. Will go out and see in I have a bad ground.
    No load it will still spin.....Put a load on the motor then try it again..Also just banging the motor will loosen stuck brushes...For a short time...On my Ex-2011 Tri-Glide..I had mine out 3 times and every time it was the brushes, And then i went to a mechanical reverse no brushes to worry about any more......
    Just for grins, reset the breaker to see what happens
    30+ Posts
    Sep 2021
    lake wales fl. USA
    Ok yes it was the brushes stuck. I am going to order a new motor any way's. This one look's like it has had a lot of ware. The ground brushes where stuck so cleaned them up and sanded them some so they where swollen. Cleaned the armature and the commutator. Sprayed every thing with contact cleaner. Put it back in the bike and work's well. Figure it will do it again till I get the new motor. Thanks for the info and the help.
    40+ Posts
    Jan 2016
    Litchfield, Ohio, USA
    Pulled my 2012 reverse motor apart today after it did not work this season. It had worked off and on last season and I figured it was the brushes. When I pulled it apart, three brushes were stuck retracted. One was still working and sliding through the retainer. There was water in the area and it had actually rusted the retainers and around the brushes. The plate the springs and retainers are attached to was very dirty also.
    I put the brush plate in a small peanut butter lid and filled it with brake cleaner soaking the plate and brushes. Using a small paste brush, I brushed all the grease, dirt and rust off the assembly. I blew off the assembly with air and it cleaned up pretty well. The brushes now slide in and out of the retainer very smoothly.
    Tomorrow I will clean the grit from the rest of the parts and put it all back together for a bench test. I suspect it will work properly once again. I will look into a way to put a little silicone calk over the parting line where the cap is screwed onto the motor body and try to keep some of the water from getting in there.
    Sometimes you just have to take things apart and find out what is going on inside.
    Sam
    Sep 2016
    Springfield, Mass. USA
    Interesting, "please" let us know how you made out repairing it. OK?
  11. #10
    40+ Posts
    Jan 2016
    I put the cleaned and assembled reverse motor back in this morning. Still had it up off the lift so I could check the operation with the rear wheels off the lift. It went into reverse very nicely and sounded real good. After putting it down on the lift and putting the ramps back on the lift I backed it off using the reverse. worked fine.
    Side note> I looked up the brush plate with brushes on the internet. I found a place that is selling a complete brush plate assembly for $17.90 with no shipping charges. I have no idea if this part is any good or not. For this price, I did order one and its on the way. I know the one I just cleaned up and put back into my reverse motor will suffer from brush sticking again and probably in a year or so. I will have the replacement already on my shelf for the next time for the price I have to try it.
    maniacelectricmotors.com
    Thanks, Sam
  12. #11
    10+ Posts GunHawk's Avatar
    Sep 2021
    Maybee, Michigan, USA
    Do you happen to know the part number for the brush assembly?
  13. #12
    Quote Originally Posted by GunHawk View Post
    Just Google........Harley reverse motor brushes..And your screen will light up with all kind of options....From 17 dollars up to 500 dollars..Depending if you just want the brushes and plate...Or a full rebuild kit...
  14. #13
    a lot of brush sets can be found on flea bay
    https://www.ebay.com/itm/15386129638...xoCfPEQAvD_BwE
  1. Cruise Control Not Working...
    By Markie in forum Stallion Trikes
    Last Post: 09-02-2015, 01:36 PM
  2. tail lights not working.
    By Biker-Dave in forum Harley Trike Conversions
    Last Post: 04-20-2012, 06:26 PM
  3. Turn signals not working
    By Las Vegas Biker in forum Stallion Trikes
    Last Post: 01-07-2011, 12:01 PM
  4. Driving Lights not working
    By Big Dog in forum Stallion Trikes
    Last Post: 05-09-2009, 07:33 PM
  5. gauges on dash not working
    Last Post: 01-19-2009, 09:39 AM
