Results 1 to 9 of 9
Thread: Front Brake Material?
    100+ Posts
    Sep 2017
    Clinton Township Michigan usa
    Default Front Brake Material?
    I would like to know if I can put Ceramic pads on the front and rear of my 2008 Stallion?
    Sure, ceramic brakes are a very good choice for braking, low dust and better stopping power when hot = longer pad life and less noise
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Have you checked your brakes? I have 55000 on my Stallion and I'm no where near needing brakes. Rick
    Stallion #378
    Suzuki Burgman 650
    100+ Posts
    Sep 2017
    Quote Originally Posted by rocket1lf View Post
    I have 17000 on mine but I have had warped rotors on it since I bought it 3 years ago. I could probably wait until until spring time but I'm going to be in a veterans day parade on Nov. 7th and possibly be part of the road crew as a blocker to the intersections.
    Each year here in Detroit we generally have about 400 bikes show up for the Veterans Parade so I want to feel comfortable in it. I just wanted to know if it is okay to put ceramic brake pads on my stallion or if I need to keep the original regular break pads on it. I'm going to do both the front and back and I know I can put ceramic on the back, I just didn't know if I could put them on the front since the rotors are motorcycle rotors?
    Dec 2013
    Hot Arizona, USA
    I thought I had warped rotors on mine also. It turned out to be the bushings on the bottom shock mounts were worn out. I replaced them and everything has been fine. Rick
    Stallion #378
    Suzuki Burgman 650
    100+ Posts
    Sep 2017
    How many miles did you have on your stallion when you found out about the bushings on the bottom shock mounts?
    Dec 2013
    Hot Arizona, USA
    25-30K There is a lot of weight sitting on them. Rick
    Stallion #378
    Suzuki Burgman 650
    100+ Posts
    Sep 2017
    Okay thanks, I will have them checked. I bought the Stallion with 13500 on it and they were warped already at that time.
    300+ Posts
    Signal Mountain Tn
    My original rear pads wore down to metal at 35K. I replaced the rotors and installed ceramics and they are holding up a lot better.
  1. Passenger backrest material repair
    By Halfnormal in forum Harley Tri Glide
    Last Post: 02-03-2020, 07:35 PM
  2. Reference material
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 02-07-2013, 10:16 AM
