BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  2
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: pressure switch in air ride needs replaced, where get?
    Nov 2021
    new smyrna beach, florida, usa
    Default pressure switch in air ride needs replaced, where get?
    I have a 2005 Honda Goldwing Motor Trike conversion. I believe the air pressure switch controlling air bag suspension is not working correctly. Where can I find a replacement switch?
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by gstonerock View Post
    Look on the Motor Trike site and find the closest dealer near you and give them a call.
    200+ Posts alwrmcusn's Avatar
    Mar 2013
    Rockwood, TN
    I ordered mine (entire unit is how MotorTrike sold it) from MotorTrike direct.
    1. My voltage meter was not filling in all of the LCD sections when I first start the bike but it would give a full reading after a few minutes.
    2. The air pressure switch would only activate the air pump after repeated tries. Sometime it would not activate at all. The air release however would always drop the pressure which made the failure to activate the pump even more of a problem.
    I had my mechanic (Luke Ritter at Kustom Bike Worx in Jamestown, TN) do the installation so he could ensure the proper power was being supplied.
    The new unit works only slightly better. So I'm not at all sure that the switch unit itself is/was totally at fault.
Size:  304.5 KBName:  DSC_0115.jpg
Size:  657.8 KBName:  DSC_0163.jpg
    FRA Branch 294 Crossville, TN
    PGR Rider
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    This may not apply because I will admit I'm not sure how Motortrike handles the suspension. I know on my CSC, it maintains the factory rear suspension adjustor.
    Before I triked my 07 (bought used in 2014) in 2016, I did have a couple of random times where I would have the suspension not work. It would increase but not decrease or even would give me a suspension error message. It actually started happening more frequently after the conversion and was driving me nuts. I did a bunch of troubleshooting and was stumped. I checked the switch as well as relays and everything seemed OK. I don't remember why but somehow I ended up checking the connectors on the rear of the dash. This is not mentioned in any of the troubleshooting guides.. There were 3 connectors back there. I was able to reach up through the fork tunnel while up front and began to check them by pushing them in. I discovered the connector towards the clutch side wasn't pushed in all the way. I pushed it and heard a click and now it was fully seated. I haven't had any issues since and that was probably at least 3 years ago. Because it wasn't fully seated, it would have intermittent problems with suspension. The only thing I can think of was that the dash had been removed at some point before I bought it and the connector was never fully pushed in. That cause the initial issue. When the trike conversion was done, I would assume that the dash had to be loosened in order to install the rake kit and this may have cause stress on the connector and pulled it out slightly more.
  1. On/Off switch and Kill switch protocol
    By kodiak198 in forum Harley Tri Glide
    Last Post: 11-07-2019, 02:51 AM
  2. ***DK Custom Products Air Pressure Dial Gauge for Air Ride Systems***
    By DK Custom Products in forum DK Custom Products
    Last Post: 06-11-2019, 11:19 AM
  3. Air shock air pressure?
    By Urlawyer in forum Harley Trike Conversions
    Last Post: 07-02-2016, 02:11 PM
  4. Replaced Air Bags on Motor Trike
    By paid4c4 in forum Honda Trikes
    Last Post: 05-31-2016, 10:08 PM
Tags for this Thread
