I have a 2020 TriGlide. I am trying to locate a Baker or other brand shift drum assembly that will move Neutral to the bottom instead of between 1st and 2nd. This will give a shift pattern of N-1-2-3-4-5-6. I have a prosthetic left leg so using a standard shifter is not an option. I have installed a Pingel electric solenoid so I can shift up or down with push buttons on my handlebar. The problem is I cannot find neutral. Baker used to make one but stopped making them shortly before I tried to order one. They took my order then after a month said they were no longer available. If anyone has one on a shelf for a 2020 TriGlide, I would be very interested. Apparently the demand for it for the M-8 motor is not that great. It is available if I buy a Grudge box from them but changing the transmission for $4,000 dollars instead of a $300 part does not make sense to me.
