Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  1
Results 1 to 6 of 6
Thread: Loud popping noise from speakers when turning off the bike.
    150+ Posts Motogordo's Avatar
    Aug 2011
    Delanco,N.J. 08075 U.S.A.
    Default Loud popping noise from speakers when turning off the bike.
    The previous owner had installed various different stereo systems. When I turn off the engine, it make a loud pop from the speakers.
    Also, what is the little square button below the volt meter ?
    Name:  2021-11-22 11.22.2021 001.jpg
    I am referring to the white button with the wire attached.
    Jun 2008
    Lovington, NM, U.S.A.
    Driving lights? Adjustable front suspension? Those items to come mind. The only other thought I have is to open up the area and follow the wire to see where it ends.
    There could be a fault in the wiring or the stereo itself.
    Retired trike builder
    Aug 2011
    Default Popping sound from stereo when shutting down.
    Quote Originally Posted by trike lady View Post
    There could be a fault in the wiring or the stereo .
    I will look into the problem. Thanks.\
    Gordon
    Aug 2011
    Default Popping noise in speakers when shutting off engine
    Nov. 24, 2021
    It stopped making the popping noise. It seems to be from the aftermarket stereo system. If I set the audio switch to headphones, it no longer pops when being shut down.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    My best guess: I would bet it is from an amp having been installed in the aftermarket system. The amp powering off will cause a brief voltage spike and the speakers are reacting to that. That is what you are likely hearing.
    Feb 2022
    Frisco, TX, USA
    Often times if an installer connects the amp power in and the remote lead to the same wire you hear a popping noise when you turn the big off. The resolve would be to separate the remote wire to the main power wire going into the amp. Try to find a wire that only has power when the bike turns on and has no power when the bike turns off. Connect that to the amps remote wire. You may also want to see if the amps main power is reading the battery voltage when the bike is turned off. If so your good, if not then that has to be rectified as well.
  1. Loud rubbing noise when turning or going slow
    By Motogordo in forum Lehman Trike
    Last Post: 05-30-2019, 06:16 AM
  2. Loud Clanking Noise
    By nefty123 in forum Honda Trikes
    Last Post: 12-31-2016, 12:19 AM
  3. Loud CLANKING noise when shifting gears up or down
    By trick trike in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-28-2016, 03:26 PM
  4. Loud pipes are TOO loud!
    By zoood in forum Harley Trike Conversions
    Last Post: 06-25-2014, 08:15 AM
  5. Got the popping fixed!!!!!!!
    By krooozn in forum Honda Trikes
    Last Post: 05-30-2011, 12:05 PM
