LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  22
Thanks Thanks:  1
Results 1 to 20 of 22
Thread: Front Tire
    May 2016
    New Waverly, Texas, USA
    Default Front Tire
    I want to replace my front tire again, I have a 2016 Wing, with a CSC trike kit, I ride very aggressive, and I want to see if anybody is running the Goldwing back tire on the front of there trike. I probably get maybe 10,000 miles out of my front tires now, and they are the Elite4.
    I have a 2019 Indian Roadmaster Elite with a DMC side car, and the shop recently put a rear tire on the front of it, and put the rotation on backward,
    I want to know has anybody done this to there Goldwing trike? If so which tire you running and what size? Does anybody know where I can get any information on this?
    Thanks Nudels
    2014 HD Ultra Classic Screaming Eagle
    2015 Honda Goldwing Level 3
    2016 Honda Goldwing Level 3/CSC Trike
    "It's a beautiful day to ride just some days are more beautiful than others"
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I am pretty sure Avon makes a front trike tire for the Goldwings. Check them out on google.
    I've used one on a Harley Trike and it is very sticky AND lasts a good number of miles.
    Also, I've been running rear tires reversed on Harley Trikes for near a decade with good experience.
    www.DKCustom.com
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Kevin's video provides all the good information about running a rear MC tire backwards on a trike. I am running a Michelin Pilot Activ 130/70-18 rear MC tire backwards on the front of my 2008 Goldwing/CSC trike. The tire was on the bike when I bought it, so I have no idea how many miles it has. But, I've put over 12,000 miles on it and it still has a few more before needing replacement. Hope this helps..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    The Avon Cobra Chrome Trike tire,Michelin Pilot Active Rear,and Bridgestone Bt-45 Rear have been the go to tires for quite awhile.The BT-45 has been replaced with BT-46.Each has its good and bad points.The Avon was designed to be a trike tire and is a radial.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    I used a Bridgestone BT-45 on the front of my Goldwing Trike,it worked out very well. The Avon trike tire is reported to be very good also.
    Happy TRAils/NSD
    Paul
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    I have used the Bridgestone Battlax BT-45 and it is a rear tire that gets mounted on the front. It provided many miles to me. Problem with it was that it's a bias ply tire and gave a stiff ride. I had to run it around 36-38psi or it pounded me on the bumps.
    That got finally switched out to a Michelin Pilot Activ which was also a rear tire mounted on the front. It too gave me many miles but suffered due to it being a bias ply so was also run at 36-38psi.
    I now have the Avon Cobra Chrome AV-91 tire on front. This, hands down is my favorite choice for front tire. This one is different due to it being a radial and I am running it at 41psi and gives me a nice smooth all around ride. It grabs the road very well. I did just put this on middle of last year so I'm not sure on how many miles I will be able to get out of it. But it is wearing well. If you decide to look into this be aware that there are 2 AV-91 tires in this size. The one you want will have "TRIKE" on the sidewall.
    And before someone brings it up, I did disable the ADV (anti dive valve) but still had a rough ride with both the BT45 and MPA bias plies unless I lowered the tire pressure but didn't completely smooth it out. Switching to the AV-91 radial was the best choice and greatly improved the riding experience. Unfortunately the price on these have gone up and they aren't cheap.
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Thanks for all of the great information guys.
    My bike is a 2021 Harley Ultra, and it is being triked in March.
    My bike only has 780 miles on it - so, the front tire is new. In the past, when I owned my GW (back in 1996 or so), I used to run a rear tire in my MotorTrike and did so with it in reverse. Back then, this is what everyone did. If you had a sidecar on your bike, you did the same things. Now, all of a sudden, this is coming back.
    So, once my bike is done and that first tire wears out, i will again go back to a rear tire, reversed. Great info on the Avon that says trike - that us new info for me.
    Thanks again
    Jul 2016
    Quote Originally Posted by cycle7447 View Post
    Thanks again
    Just wanted to mention, the front Avon Venom for Harleys is a bias ply. The Goldwing version is a radial. But they will say Trike on the sidewall.
    https://www.avontyres.com/en-us/tyre...a-chrome-trike
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Quote Originally Posted by pwhoever View Post
    Thanks- will have to look that us. Thought I checked yesterday and it said Radial for the Harley
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I ran a BT-45 on my last Trike and loved it. I just bought the new BT-46 and will have it installed if this current weather ever ends here in Southern Ohio.
    300+ Posts paid4c4's Avatar
    Mar 2016
    Crestview Hills, KY, USA
    Quote Originally Posted by FRR View Post
    Planning on the same thing here in Northern Kentucky. I'm going to also add tire monitor sensors. It's a small world.
    Bill
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by paid4c4 View Post
    Bill
    Tire goes on next Tuesday or Wednesday
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Bill
    Bill, had my front tire installed today. The BT-46 Turned out the rotor had to be removed since the forks were too tight to get the tire out. Looked like someone at the installer had tightened the pinch bolts before the axle nut and pulled it together. Took 1 1/2 hours to change the tire. ( you can guess what that cost). I called CSC and Will said they have seen several forks come in that were machined wrong and had to be "widened" but they wouldn't trust a dealer to do that. I told him I was over 7 hrs from the factory and he said he would check with the boss and see what he could do.
    I will keep you informed.
    90+ Posts Sandman1's Avatar
    Jan 2021
    Palm Harbor, Florida, USA
    Cool Proper spec for CSC fork?
    ***Can you let us know what the proper specs should be on the CSC forks as well. Had my 2018 GW DCT Tour CSC kit installed back last April, curious. TIA.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by Sandman1 View Post
    I did hear back from CSC and they admitted they had had a issue the past year with some forks ordered that were " not correctly speced" Now they are measuring every one. They have agreed to replace the forks and are working it out that a dealer in Ohio will do the installment sometime this Spring. I'll have to ride about 160 miles from home, but it beats 460 to Virginia. If you contact Will at CSC he can give you the proper specs, I'm sure. Hope this helps
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I did about 80 miles with the new tire on Sunday. Very happy with it. Appears to have better control than the stock one that was original equipment on the bike. I think you'll like it
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Bill
    Are you considering tire sensors for the rear? Will the bike read them? We already have TPMS on the front.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Bill
  19. #19
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Lots of information here about the front tire.
    I was at my dealership on Saturday - and they were doing a "Fat Tire" install. Harley has a kit that replaces the front tire and wheel for their bikes.
    Essentially, it's a rear wheel run backwards. Wife and I thought just howe nice this would look on our new trike. Sounds like several of the other guys thought the same thing.
    Sounds like the kit is around $750 and the includes the wheel, tire and fork adjustments. Still, you have to buy a new fender.
  20. #20
    Jul 2016
    This has already been done on Goldwings. Hannigan offers their 180 front end kit which is a new wheel and car tire but IIRC, it's a several thousand dollar option because not only does it require new wheel and hardware but new triple tree to accommodate the increased width of the forks to handle the wider tire. There is also the leading link front end but I don't know too much about it.
    I will say that I'm really surprised that the Harley version would only cost around $750. I would think it would be tremendously higher in cost.
  1. Avon AV-71 Front Trike Tire - anyone using this tire???
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 02-16-2024, 04:24 PM
  2. Tire Pressure for MPA Front Tire
    By cScjhb in forum Honda Trikes
    Last Post: 09-13-2020, 12:11 PM
  3. tire size for rear tire on front? 2007 goldwing trike
