Likes Likes:  4
Results 1 to 8 of 8
Thread: Shifting into reverse with a manual reverse.
    Dec 2012
    Santee
    Default Shifting into reverse with a manual reverse.
    For all you people with a manual reverse gear, how do you get it to shift into reverse without grinding a pound of two and without it almost giving you whiplash? Installed a MotorTrike reverse last week and when finished and tried to shift into reverse, it sounded like I had shifted gears without using the clutch. I know that is not good on the small idler gear and bearings.
    Ray
    2017 Harley Triglide
    Tijuana Border
    Quote Originally Posted by Rmitchell55 View Post
    In ''Neutral'' .....''Engine Off''...Reach down put the lever into reverse ..Then with the clutch in.. Start the engine ease off the clutch....And feed gas ...Thats the way i did it with my 2011 Tri-Glide........
    Bob, are you saying you have to shut it down before using reverse each time?
    Wouldn't a good clutch adjustment solve the problem provided it was not a hydraulic( non adjustable) clutch
    Let me Splane ....I pull in a parking space that i will have to back out of after I park the Trike , And then when i come back before i start the engine i slip it into reverse start the trike and ease off the clutch and back out..I never had to use the reverse with all the 3 Trikes i had....Mechanical or Electric thats the only time i ever needed to use reverse
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    Motor Trike manual says start engine in N , shift to first and then back to N. This stops the gears from spinning and then you put trans into reverse with no drama.
    20+ Posts
    Nov 2010
    Saginaw, Texas
    Quote Originally Posted by OLBLU View Post
    That is how I do mine and no grinding.
    100+ Posts kingfish108's Avatar
    Jan 2018
    Lee's Summit, MO, USA
    Quote Originally Posted by mhonn2002 View Post
    Do the same and also changed to heavier trans fluid.
    150+ Posts
    Firewrench22's Avatar
    Oct 2014
    Kingston WA USA
    If I am pulling into a place where I will need reverse, I shift into reverse before toeing it out of first gear.
    If stopped, I do as above and start it in reverse.
  1. Parts manual/ service manual
    By ODDOMAN in forum Stallion Trikes
    Last Post: 02-11-2021, 08:01 AM
  2. Shifting and NOT shifting
    By Zorro in forum Honda Trikes
    Last Post: 07-25-2014, 10:02 PM
  3. hard getting into mechanical reverse
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 02:25 PM
  4. Hard Shifting
    By Mcwac in forum Harley Trike Conversions
    Last Post: 08-23-2011, 08:57 AM
  5. Noise when shifting gears
    By meredog in forum Honda Trikes
    Last Post: 08-29-2010, 09:52 PM
