Likes Likes:  20
Thanks Thanks:  1
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 47 of 47
Thread: Intermittent electrical
  1. #41
    400+ Posts
    Sidecarbill's Avatar
    User ID
    18278
    Feb 2015
    Sussex nj usa
    Rep Power
    164
    Work backwards from the battery with a test light. See where it goes out.
  2. #42
    82000+ Posts
    User ID
    6298
    Paradise New Jersey USA..
    Rep Power
    300
    I wound't be surprised if after all is said and done a ''New Battery'' would solve the problem..AKA---Occam's Razor....
  3. #43
    20+ Posts
    User ID
    32832
    Oct 2021
    Cleveland Texas USA
    Rep Power
    11
    Default Has a new battery
    It has a new battery. Electrical is my weakest skill going to try to see what I can find with test light.
  4. #44
    14000+ Posts
    User ID
    24367
    Rep Power
    300
    I would first scan the ECM to see codes, this will give you an idea where to look for the problem
    You could have multiple codes stored now
    Nuff Said," Were Burnin Daylight, Lets Ride"(Sober 33years)
    Current ride : 2021 FREEWHEELER M8
  5. #45
    20+ Posts
    User ID
    32832
    Oct 2021
    Cleveland Texas USA
    Rep Power
    11
    Default Cable
    I agree after some thought. I had to go online and order the 4 pin cable to connect my handheld to the motorcycle ob connector. It's arriving today. Wish me luck.
  6. #46
    400+ Posts
    User ID
    18278
    Feb 2015
    Sussex nj usa
    Rep Power
    164
    Just curious. The new battery was installed to correct this problem or previous to this problem? I had a battery less than 2 weeks old go bad in a similar manner. Battery showed 12.6 but put load on it drop right off. Leave it sit for a minute and the voltage would slowly come up to normal.
  7. #47
    20+ Posts
    User ID
    32832
    Oct 2021
    Cleveland Texas USA
    Rep Power
    11
    Default Battery
    I replaced at the start of the issue. It cranks just fine..bike starts and runs a few moments and then everything goes dead.
  1. Intermittent Engine Stall, Shutdown
    By TejasRanger in forum Harley Freewheeler
    Last Post: 04-30-2021, 04:05 PM
  2. Intermittent starting problem
    By Stalloin 146 in forum Stallion Trikes
    Last Post: 09-09-2011, 05:44 AM
  3. electrical problem, volt meter in 12v range
    By silverdevil in forum Stallion Trikes
    Last Post: 03-12-2010, 11:50 PM
  4. Electrical Problem - Blowing Fuse
    By patriot in forum Honda Trikes
    Last Post: 10-15-2009, 08:50 AM
  5. Electrical Woes
    By Ozarkryder in forum Honda Trikes
    Last Post: 06-15-2009, 08:54 AM
Bookmarks
