Likes Likes:  26
Thanks Thanks:  1
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 53 of 53
Thread: Intermittent electrical
  1. #41
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Work backwards from the battery with a test light. See where it goes out.
  2. #42
    I wound't be surprised if after all is said and done a ''New Battery'' would solve the problem..AKA---Occam's Razor....
  3. #43
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Has a new battery
    It has a new battery. Electrical is my weakest skill going to try to see what I can find with test light.
  4. #44
    I would first scan the ECM to see codes, this will give you an idea where to look for the problem
    You could have multiple codes stored now
  5. #45
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Cable
    I agree after some thought. I had to go online and order the 4 pin cable to connect my handheld to the motorcycle ob connector. It's arriving today. Wish me luck.
  6. #46
    400+ Posts
    Feb 2015
    Sussex nj usa
    Just curious. The new battery was installed to correct this problem or previous to this problem? I had a battery less than 2 weeks old go bad in a similar manner. Battery showed 12.6 but put load on it drop right off. Leave it sit for a minute and the voltage would slowly come up to normal.
  7. #47
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default Battery
    I replaced at the start of the issue. It cranks just fine..bike starts and runs a few moments and then everything goes dead.
  8. #48
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default It was the circuit breaker
    After pulling out half the hair I have left I got out out my miners headlight and magnifying glass and I found hair line Crack in the circuit breaker. Replaced it and so far all seems OK. Waiting until after lunch and I'll take it on a trial run to be sure. Wish me luck.
    Y
  9. #49
    Good Luck, and check back in
  10. #50
    30+ Posts
    Oct 2021
    Cleveland Texas USA
    Default All good
    Rode for an hour yesterday afternoon. No issues. Thanks for all your help. Let this be a note to everyone "always wear your glasses" if you can't see. 😉
  11. #51
    Good on you
  12. #52
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Happy you got it fixed. Ride safe.
  13. #53
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Quote Originally Posted by Clevelandpat View Post
    Good morning. Have an electrical issue on my 2001 Rood King. Riding home and everything went dead at stop sign. Everything went dead. No lights...nothing. turned switch off then on and started right up. Got to my driveway and everything dead again. I coasted to a stop. Nothing at all...everything dead. Parked for the night. Next day checked battery dead. Trickle charged...bike started but everything went dead again after 5 to 10 seconds. After few seconds light come back on. Hit starter..starts..runs 5 seconds..then everything goes dead. When it goes dead, the flasher behind the battery clicks ...any ideas?
    Good to know you found the issue,if I have this issue with my 2002 Road King I will try and remember this post.
  1. Intermittent Engine Stall, Shutdown
    By TejasRanger in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-30-2021, 04:05 PM
  2. Intermittent starting problem
    By Stalloin 146 in forum Stallion Trikes
    Last Post: 09-09-2011, 05:44 AM
  3. electrical problem, volt meter in 12v range
    By silverdevil in forum Stallion Trikes
    Last Post: 03-12-2010, 11:50 PM
  4. Electrical Problem - Blowing Fuse
    By patriot in forum Honda Trikes
    Last Post: 10-15-2009, 08:50 AM
  5. Electrical Woes
    By Ozarkryder in forum Honda Trikes
    Last Post: 06-15-2009, 08:54 AM
