Likes Likes:  4
Thanks Thanks:  2
Results 1 to 10 of 10
Thread: Rear tire removal
    Jan 2021
    Merritt Island Florida
    Default Rear tire removal
    Any tips or tricks to remove the rear tires off a 2016 Goldwing Roadsmith trike with independent suspension? I used the center plate jack location, it lifts the entire rear of the trike and does not allow the wheels to hang lower than the body. Am I missing something? I know that the tires is tightly tucked in there, so I’m not sure if there’s something else that I should be doing. Thanks in advance. Robert
  2. Roadsmith banner
  3. #2
    Sep 2016
    Springfield, Mass. USA
    Robert,
    Although I have never removed a tire off my Roadsmith, I can only assume that all you have to do is to remove all lug nuts, and be sure to have the trike lifted high enough to just let tire drop down....
    If there's a secret that I don't know ............... "I'm all ears"
    1/16/22
  4. #3
    Jan 2021
    So, after studying the situation more closely, I had to wiggle the wheel/tire side to side and up and down after clearing the studs and sliding the rear of the tire out of the wheel well first while rotating the front to the inside of the space and then pulling the wheel out at an angle ( it will rub the opening on the way out). Not exactly like removing a wheel off of a vehicle. Basically, the tire is 27 inches and the opening is about 25 inches, if that makes any sense. The suspension does not allow the wheel to drop anymore than a couple of inches so dropping it out the bottom is not an option. Going back on was just as tricky, but at least I know what to do the next time.
  5. #4
    250+ Posts
    Jan 2012
    oz
    It depends what model of trike kit you have, On my Goldwing HTS1800 kit, jack the tire up a few inches off the ground, remove lug nuts. Tires come off like a car
  6. #5
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    The back wheels/tires are tight coming out from under our CSC trike with independent suspension also. Glad you figured it out Robert!
    Sep 2016
    Thanks for letting me know, cause I plan on changing my "rears" this spring time before April 1st...............
    My bike is still in garage up on jacks, covered over, with battery maintainer plugged in..... Temp in garage is a balmy 18* warm as we speak.....
    2/5/22
    80+ Posts
    Feb 2014
    Toledo,Ohio-USA
    Brethren,
    Be sure When Removing That Tire That You Support The Opposite Tire, Otherwise The Trike Will Tilt Sariptishlly Or Dangerously To The Opposite Side, Ask Me How I Know
    Sep 2016
    Quote Originally Posted by Ayatolla of Rockin' Rolla View Post
    Brethren,
    Good suggestion here: thank you...........Now that you have mentioned this, YOUR RIGHT, The wheels are balanced, so once you remove one wheel, the weight will tip the whole trike..................Dang man , thank you, again....
    2/12/22
  10. Roadsmith banner
  11. #9
    10+ Posts Bama Jack's Avatar
    Mar 2018
    Smiths Station, AL U.S.A.
    Red face Tilt
    Brethren,
    Yes it will tilt unexpectedly. Don't ask how I know!
  12. #10
    20+ Posts Gripman's Avatar
    Mar 2014
    Greenbank,WA
    Default lifting rear of roadsmith trike
    place the jack to the far end of the center plate next to the bolt thats hanging just below and to easily remove the wheel twist so that the front or rear of the tire comes out first.
    Joseph
  1. Front Tire/Rim removal
    By jc1300 in forum Harley Tri Glide
    Last Post: 10-08-2017, 09:30 AM
  2. Tool For Champion Trike Back Tire Removal
    By FRR in forum Honda Trikes
    Last Post: 07-02-2016, 04:32 AM
  3. tire size for rear tire on front? 2007 goldwing trike
  4. removal of rear box and fenders
    By gregC. in forum Harley Trike Conversions
    Last Post: 06-04-2014, 11:20 AM
  5. Rear Fender Removal
    By bigb in forum Harley Trike Conversions
    Last Post: 06-02-2013, 02:44 AM
