Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  7
Thanks Thanks:  2
Results 1 to 16 of 16
Thread: Battery post relocation.
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Default Battery post relocation.
    Has anyone installed or has anyone considered installing a Battery Post remote terminal relocation kit? This would make it easier for a jump if it is ever needed and give easy access to battery terminals without removing the seat, the ECM and everything else that's under there to get at the battery. It could be relocated under a side cover. All current connections would remain the same on the battery terminals. Just thinking out loud.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Never saw one .For that matter ,never heard of one. That said it would be a lot easier if you need a jump.
    I have jumped started by hooking the hot lead of a jumper cable to the main battery lug @ the starter and ground cable on the frame, but you need to be very careful
    Jul 2017
    Cherokee Village, AR, USA
    Default battery post relocation
    I got a battery tender wire connected to the battery{under side cover} for easy hookup & I got the same type of wire connecter and add6 ft. of wire & got medium size red -black battery clips attached them & carry them wrapped up if needed just plug in battery tender wire hope this helps
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    1
    I’ve used the hot lead on the reverse circuit breaker .
    That is a lot easier, good tip
    30+ Posts
    Jan 2022
    Buena Vista
    pretty much a trickle charger hookup would do what u looking for, and yes they are helpful for charging or connecting a jump box
    I use them on M/C and my Mule
    Quote Originally Posted by bear1953 View Post
    My Trikes came with that hook-up..[Pig Tail].....And yes in time you can charge the battery....But that hook-up can't handle a boost from another battery...AKA Jump Start.
    Exactly, very bad JU JU
    I see it now, like trying to arc veld with welder hooked up to a cheap extension cord rated for 110 volts
  11. #10
    50+ Posts
    Mar 2013
    Altoona, Pa
    I carry a compact jump box and have the connection point behind the right side cover, very convenient if ever needed
  12. #11
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by al704 View Post
    That's exactly what I'm talking about.
  13. #12
    Oct 2018
    Ramseur NC USA
    They make several kits for ATVs. The one I have my eye on would be very easy to hook up to a TG.
  14. #13
    100+ Posts NJtony's Avatar
    Oct 2021
    Manahawkin
    Is this what you are looking for?
    https://www.amazon.com/Battery-Charg...a-821654282763
  15. #14
    Oct 2018
    Ramseur NC USA
    After looking at the bike, it never occurred to me to use that has a hot lead for emergency jump. That kind of takes care of my problem thanks
  16. #15
    900+ Posts
    Bellville, Texas, USA
    Have done this also. Works fine.
    Sunman
  17. DKCustoms postbit
  18. #16
    30+ Posts
    Jan 2022
    Buena Vista
    I have used that pigtail many times to jump from a handheld box such as the Noco boost plus, they make a adapter that plugs directly to the pigtail
    NO not meant to jump from car battery or larger jumpbox but for the smaller handheld ones it works fine.
    Also depends on what gauge wire u use to make your pigtail
  1. Old Battery vs New Battery
    By Baldy_54 in forum Honda Trikes
    Last Post: 12-05-2023, 10:15 AM
  2. Battery life and battery purchase
    By pcombe in forum Harley Trike Conversions
    Last Post: 02-21-2019, 05:53 PM
  3. Tour Pack Relocation kit
    By Harley Don in forum Harley Trike Conversions
    Last Post: 08-13-2013, 11:27 AM
  4. Tourpac Relocation
    By mervt198 in forum Outrigger Style Trikes
    Last Post: 01-25-2012, 06:52 PM
  5. Passenger peg relocation for Frankenstein 34" Hot Rod rear.
    By trikes4ever in forum Harley Trike Conversions
    Last Post: 10-29-2010, 11:35 AM
