Likes Likes:  2
Thanks Thanks:  2
Results 1 to 14 of 14
Thread: Independent rear suspension ??
    100+ Posts
    Apr 2019
    Lewisville
    Default Independent rear suspension ??
    Hi Alla'all ;
    I recently had the opportunity to ride a Freewheeler and was shocked at the ride and handling.
    I have ridden a few Goldwing trikes and there was nothing to compare between the two.
    The Goldwing's have IRS
    Do the newer Freewheelers come with IRS or is it possible to retro fit IRS to one ??
    Any idea how much an IRS setup would cost ?
    Thanks to any reply's , Doug .
    Jan 2009
    MA,
    Quote Originally Posted by Douglas44 View Post
    Hi Alla'all ;
    I think it would be around $ 10000.00 Having it done by a shop. maybe a little less you do the work yourself, Then if it was still under Harley warranty That would be cancelled.
    The factory does not have independent suspension for the trike line
    Jan 2009
    MA,
    I Thought he was talking aftermarket .
    Yes, the factory does not do independent, but the aftermarket makes kits
    https://www.kooltrikesnorth.com/tri-glide-upgradeHere,
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    I thought HD rejected independent suspension as having poorer handling, disconcerning cornering and for the added expense just wasn't worth the effort. It's hardly worth comparing a Goldwing Trike to a Freewheeler. They're not designed for the same thing.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    From Kooltrikes site
    HARLEY TRIGLIDE / FREEWHEELER INDEPENDENT SUSPENSION UPGRADE
    Are you disappointed with the ride quality of your Tri Glide or Freewheeler? Soften your ride with the proven Kool Trikes smooth riding TriGlide / Freewheeler Independent Suspension upgrade!
    *$6895 INSTALLED
    100+ Posts
    Apr 2019
    Lewisville
    Thanks for the replies , I really appreciate the help .
    I like the idea of the Freewheeler because it reminds me of my Road King, no radio, just a wind screen and a detachable GPS .
    The one I test rode was so bad, ride and steering wise. I thought it was broken .
    Took it back to the shop and they said that's how they all ride . If that's the case then I'll pass.
    The shop wasn’t lying….But just to ease your mind go to a different dealer and do another test ride…There’s a lot of things you can spend your money on to convince you it rides a little better…But it’s all relative…They are what they are 🤔..
    Jan 2009
    MA,
    Quote Originally Posted by JTJersey View Post
    What are they designed for ?
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    The Freewheeler is a sport trike. The Goldwing is, well a Goldwing. A two wheeled Cadillac (or in this case a three wheeled conversion) designed for biking comfort and luxury, as much as a trike can be luxurious out in the open weather and all. If you want a Cadillac fine, just don't expect a Corvette to be the same thing.
    750+ Posts
    Jan 2010
    east windsor ct
    pl
    550+ Posts priell3's Avatar
    Oct 2018
    Wellsboro
    Once I got the air pressure in the shocks dialed in, the rides on our Freewheelers is just fine.
    MikeP
    2017 Billet Silver FLRT - Wife's
    2022 Vivid Black FXST - Mine
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Here is a company that makes and IRS system for Harley trikes - both TG and FW - but it ain't cheap - almost $10k for the kit plus install plus any options you might want. Does look very well made and robust.
    http://www.imctrike.com/tri-glide-prices.html
  1. Replies: 0
    Last Post: 09-19-2019, 08:32 AM
  2. Independent rear end suspension
    By Grizzlybob57 in forum Home Built Trikes
    Last Post: 10-25-2015, 12:55 PM
  3. Independent rear suspension
    By wobray in forum Harley Trike Conversions
    Last Post: 05-17-2012, 10:04 AM
  4. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
  5. Independent suspension vs straight axle
    By furofthedog in forum General Discussion
    Last Post: 04-16-2009, 02:34 PM
