Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  15
Results 1 to 13 of 13
Thread: rear fender trim
    90+ Posts
    Nov 2019
    Omaha NE
    Default rear fender trim
    I have a chip on my right fender edge that I’d like to cover up.
    Also I’d like to add some protection to prevent future chips.
    I have touched up the chip using the Harley paint touch up kit.
    That hides it pretty well and likely I’m the only one that really notices it .
    I know Harley sells a trim kit for the Triglide but I don’t think anything for the Freewheeler.
    Looking to see if anybody out there has installed edge trim or are aware of other options.
    I am probably going to add a pair of Frank’s fender bibs but that will not provide any real protection for the fender edge.
    550+ Posts priell3's Avatar
    Oct 2018
    Wellsboro
    Quote Originally Posted by Blueraven View Post
    Frank's provides great protection.
    MikeP
    2017 Billet Silver FLRT - Wife's
    2022 Vivid Black FXST - Mine
    90+ Posts
    Nov 2019
    Omaha NE
    Quote Originally Posted by priell3 View Post
    I was looking at the Harley Triglide bibs as I found that they will fit the Freewheeler.
    I thought the look was pretty good and the price was only around $100.
    However I read some reviews that they have caused damage to the fender finish.
    Also they cover more of the fender than I need or want.
    I ordered my “Frank’s” front and rear bibs today.
    I went with the same setup as what is on your Wife’s Freewheeler.
    Based on your pictures it appears the “Frank’s” bibs will conceal the pre-mentioned edge chip so they address that need of mine as well.
    Also Frank is a retired Veteran and I always if it all possible patronize Veteran owned businesses.
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    All of those bibs will eventually damage the paint unless you remove them after a ride and clean the area underneath, otherwise moisture will build up which can fog the paint and wind buffeting will cause the bib to rub the area no matter how tightly they are fitted. If you like the look of the bibs then by all means run with it, but anticipate never removing them, because your paint will show a faded and worn well defined area if you do. I speak from experience.
    90+ Posts
    Nov 2019
    Omaha NE
    Quote Originally Posted by JTJersey View Post
    As an added layer of protection I will be installing the Harley “Transparent Paint Guard Kit” that will be under the bibs.
    Also I keep everything highly waxed, very clean and rarely do I ride in the rain but if I do get it wet I would remove the bibs to allow them to dry.
    Of course there’s always the chance that the paint finish will get scuffed by the bib but I personally think that’s less likely given the Transparent Paint Guard Kit along with keeping the fenders clean and well waxed.
    Oct 2018
    Wellsboro
    Frank's fit skin tight. The wind doesn't cause them to move nor does moisture have an easy way in.
    I put them on my wife's after a few stone chips. I touched those up with a match from her vast collection of nail polish.
    MikeP
    100+ Posts W3JNP's Avatar
    Nov 2016
    Reading, PA
    +1 on Frank's.
    2008 Stallion
    Reading, PA 19606
    90+ Posts
    Nov 2019
    Omaha NE
    Quote Originally Posted by W3JNP View Post
    +1 on Frank's.
    I took your advice from a previous post.
    My Frank’s bibs are in route and should be here on Monday.
    Thanks again for the recommendation.
    Jan 2022
    Hill Country, Texas USA
    I put the paint guard kit on my trike as well. The smaller pieces came out nice, but the fenders look craptacular. I had a hard time keeping the pieces from stretching and my squeegee was too big so it's all bubbly, so I got a set of bibs from Frank's too. I'm going to keep the kit on since they will be hidden by the bibs.
    Michele, "Meesh"
    US Army, Retired 1994-2018
    Harley Freewheeler
    Oct 2018
    Wellsboro
    Did you get them and put them on yet?
    MikeP
    90+ Posts
    Nov 2019
    Omaha NE
    I got them but haven’t had time to install them.
    The instructions say it’s best to have a second person to help stretch them on so I’ve been at the mercy of my Wife’s schedule.
    I did ask her if she’d help me put on my leather bra this weekend and she looked at me a bit funny and replied “sure if that makes you happy” . My Son threw up and left the room.
    Oct 2018
    Wellsboro
    My wife assisted when I put on the front fender bra, (requires removal of fender.). I did the rear by myself, with a lot of patience.
    You'll be pleased at how well they fit. Very snug and wrinkle free.
    MikeP
    90+ Posts
    Nov 2019
    Omaha NE
    Finally got around to getting the bras/chaps installed.
    I decided not to install the clear film kit so if anyone’s interested in that shoot me an IM.
    Very pleased with the quality of the leather and fit.
    Installation wasn’t too bad once I figured out how to read.
    The left side took me probably 45 Minutes, the right side took me 15 minutes, and the front fender probably about 30 minutes.
    I still need to let them sit in the sun for a little bit and then readjust them.
Size:  1.04 MBName:  6BC20D3B-6BFC-4EC4-8E3C-2E42888D92E3.jpg
Size:  1.02 MBName:  18E53661-4076-4926-9DB9-1D8AF77036A7.jpg
Size:  1.05 MBName:  C2DCE679-618E-4566-AB44-E6590C1C6478.jpg
  1. Big Bike Parts LED Front Fender Trim
    By firefighter4634 in forum Honda Trikes
    Last Post: 12-25-2016, 09:15 AM
  2. fender well trim
    By bcop31 in forum Honda Trikes
    Last Post: 01-12-2016, 06:11 PM
  3. Top fender trim
    By Southpaw in forum General Discussion
    Last Post: 03-20-2013, 06:51 PM
  4. Fender Trim
    By americanbadass in forum Accessories
    Last Post: 12-20-2012, 07:13 AM
  5. Chrome fender trim
    By motor256 in forum General Discussion
    Last Post: 02-02-2011, 09:27 PM
