Likes Likes:  1
Results 1 to 7 of 7
Thread: Upgrading to LED headlight - not HD part
    Jan 2022
    Crystal Lake
    Default Upgrading to LED headlight - not HD part
    I just was upgrading to an LED headlight. J&P states this fits my freewheeler ('20). HogWorkz 7" LED Chrome HaloMaker Headlight Kit. The wiring harness that came with the headlight has 1 plug, and the OEM wiring harness has 2. The back of the headlight housing is sealed, so I can't get to the wiring harness and remove the entire splitter. Anyone try this headlight and how did you get it wired in and working? TIA.
    Have a look at this video to see if it helps explain the wire harness
    Jan 2022
    Crystal Lake
    Unfortunately the headlight housing is closed back so I cannot get to the 4 pin harness. Two wires pass through a small rubber grommet. Wondering if the Road King adapter will make it work.
    80+ Posts
    Aug 2016
    sebastian FL
    I have the hogworkz headlight and like it but I was irritated to discover its made in China. I contacted hogworkz before I bought it and their email indicated it was not made in China but when I got the box it said made in China.
    To answer your question I'm pretty sure there's an adapter that either comes with it or you have to buy extra and all the wiring is done through the front. You take the stock bulb out and connect the adapter and the new bulb and screw everything back together.
    Dec 2021
    Palm Bay
    Quote Originally Posted by Trikegypsy2 View Post
    I got a cheapo led headlight from Amazon. A fraction of the cost of OEM. I don't ride much at night so it's more about daytime visibility. Works great.
    300+ Posts
    Mar 2018
    Waelder, Texas
    Barb, I hope you’ve found a solution by now. I found the instructions that came with my Eagle headlight and it clearly states that there are three possibilities. Direct plug and play, an adapter for the flat plug shown in the video, and an adapter that plugs into each of the existing plugs to join them to your headlight (with part numbers). Sorry no one was able to help you. Contact the manufacturer or dealer if you haven’t. Good luck and let us know how it works out.
    550+ Posts priell3's Avatar
    Oct 2018
    Wellsboro
    On our 2017 Freewheelers I just replaced the stock bulb with and H4 LED. Plug and play.
    https://paradiselightsllc.com/shop/s...eadlight-bulb/
    I might even have one laying around in the garage.
    MikeP
    2017 Billet Silver FLRT - Wife's
    2022 Vivid Black FXST - Mine
  1. Upgrading 107 to 114
    By boeing247 in forum Harley Tri Glide
    Last Post: 11-26-2019, 07:54 PM
  2. upgrading m/t brakes
    Last Post: 09-12-2015, 06:52 PM
  3. Headlight on headlight off
    By dano2005 in forum Honda Trikes
    Last Post: 07-08-2012, 07:00 AM
  4. LED Headlight / Passing Lamps installed
    By JohnC in forum Harley Trike Conversions
    Last Post: 01-08-2012, 06:28 PM
  5. LED headlight and driving side lights
    By kiorana123 in forum Harley Trike Conversions
    Last Post: 06-16-2011, 09:34 AM
