Likes Likes:  2
Results 1 to 4 of 4
Thread: Tilt Steering
    Oct 2021
    Summerville,SC,USA
    Default Tilt Steering
    The Stallion did come with a tilt steering wheel correct? Mine has the lever but does not tilt.
    300+ Posts
    Signal Mountain Tn
    Yes indeed it tilts. Maybe you are not pulling the lever up (towards you) hard enough? Or, are you trying to go in the direction of a stop and it is already bottomed out??? Just a guess, it should work. There were some instances where the Stallion would not start if it was all the way up. If you ever run into a starting problem, try to move it down if it is up. Good luck.
    Oct 2021
    Summerville,SC,USA
    Default tilt steering
    Quote Originally Posted by trikervet View Post
    You got it. I was not pulling the handle far enough. The pull amount on it is crazy. Thanks for the help.
    300+ Posts
    Signal Mountain Tn
    Thanks for checking in. Glad to hear that it works okay for you.
  1. Freewheeler Steering vs Tri Glide Steering
    By POPSHD in forum Harley Tri Glide
    Last Post: 01-08-2020, 09:45 AM
  2. Loading Trike on Tilt Flat Deck - Mechanical Breakdown
    By ron49th in forum Harley Tri Glide
    Last Post: 03-28-2019, 08:06 PM
  3. 2002 Roadhawk trike body tilt.
    By wedge17.6 in forum VW Powered Trikes
    Last Post: 06-08-2018, 10:12 PM
  4. Tilt Bed Trailer
    By sporter in forum Trailers / Campers
    Last Post: 12-01-2011, 09:03 PM
  5. Steering Wobble
    By Pushrod in forum Harley Trike Conversions
    Last Post: 01-21-2009, 07:57 PM
