AriNV4Pegasus1300Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV4AriNVRider Safety Discuss...Maybe silly but serious question, s...
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV13trike ladyNew Member Introduct...New to trike
AriNV13GorillaNew Member Introduct...New to trike
Likes Likes:  40
Thanks Thanks:  13
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 77 of 77
Thread: New engine and oil usage
  1. #61
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by 2K1200LTS View Post
    If that much oil went through the exhaust, they probable should replace the cat and O2 sensors. Or at less make a note of it as oil deteriorates both parts.
    What they should do and what they will do are two different things and what they will tell you is what are you worried about if we put it all together and it breaks again it’s under warranty! I’ve been through that with them it’s not just them it’s all manufactures they don’t trust the dealers just like you don’t trust the dealers…. More than likely if they listen to the dealer they would want Harley to give the customer a brand new engine right out of the box…
    2019 Tri-Glide.......
  2. #62
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Zammy View Post
    Some rings were installed wrong,
    Just to add… There are two ways they can put the rings in the wrong way.. All the seams are lined up in one direction… Or placed the Oil ring in the compression ring grove or vice versa….
  3. #63
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    My money is on the wrong installation of the oil ring
    If the expander part of the ring is not butted up the top lands will push in too far not allowing oil to flow thru the ring and piston, returning to the crankcase
    This will move the oil past the rings and pistons to the cylinder
  4. #64
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Thanks..Jack….You can Splane things better then I ever can .….👍👍….
  5. #65
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    That's it Jack, the oil ring was installed upside down
  6. DKCustoms postbit
  7. #66
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    It is easy to do if you don't, double check, if I have to guess I would bet it is done by hand not a robot
  8. #67
    30+ Posts
    Aug 2019
    CATSKILL MTS USA
    Usual it's the second ring install upside down that gives the oil usage problem. Which is the one to scrape the oil of the cylinders. Oil ring are three-piece rings.
  9. #68
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Engine was put back together today and run through several heat cycles, it was late so they will test drive tomorrow but we have Dr. appointments so will pick it up the following day. New plugs installed and an oil and filter change also. So looking forward to getting back in the saddle even if we have to break it back in for 500 miles as they suggest.
  10. #69
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Sounds like your good to go Gary. Ride that puppy …
  11. #70
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    If they did several heat cycles, your new rings are already on their way to seating, ride your trike, change the oil in 1K miles and look for debris from the re break in
    Best of luck on your new top end
  12. #71
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Will be good to go for MV...
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  13. #72
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Lol, afraid not Bill, we will be in Ohio driving the cage, we will miss everyone for sure.
  14. #73
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Some very good news !!! We put on about 190 miles over the weekend and no oil usage, before they did the work I would have been down about 10-12 ounces. After the new rings were done and the oil changed they put a marker on the dipstick where the oil level was when hot. I checked as soon as we get home from our ride and the oil level was right at the mark, hoooray.
  15. #74
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
  16. #75
    150+ Posts windsurfed's Avatar
    Jul 2020
    Spokane WA USA
    Default Oil burner
    That is great news I hope it stays that way for you.My 20 TG burnes a quart about every 4000 miles. Been that way sentence new. I have 19,000 miles on it.
    Stupid is a choice
    Dumb is not a choice
    Stupid can be fixed
    Dumb cannot be fixed.
  17. DKCustoms postbit
  18. #76
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Gary, is that Syn 3 in your trike?
  19. #77
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Yes Jack, that's what they put in for the oil change, I've always used Redline but we shall see how things shake out. I've got about 700 more miles before the 5K checkup and another oil change.
  1. Freewheeler gas gauge usage
    By My Turn in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-02-2021, 09:52 PM
  2. oil light came on, low range indicator appeared and the engine died.
    By marnie in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-26-2017, 10:52 PM
  3. Gas usage on my trike
    By TNTriker in forum Harley Trike Conversions
    Last Post: 06-29-2012, 05:31 PM
  4. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
