Likes Likes:  40
Thanks Thanks:  13
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 77
Thread: New engine and oil usage
  1. #41
    OK, it is Monday I hope you had a good experience with the dealer
  2. #42
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Dealer has been great Jack, no run around at all, it's the Mothership that has to be dealt with in steps. Ok, here' s the rundown on the tests that were run:
    Compression test:
    Front - 150 psi
    Rear - 145 psi
    Leak Down test:
    Front - 5%
    Rear - 3%
    Crankshaft Position Sensor removal - 2 oz of oil came out ----- Maximum of 6 oz allowed
    Air cleaner is good to go, no goop in it
    No leaks can be found anywhere
    Exhaust pipes are not oily or overly dirty
    Conclusion, no one seems to know, lol. Per HD, they refilled oil to correct level and I have to go back in 500 miles, I don't have a problem with that so we'll see what happens the next time
  3. #43
    Those numbers look good, I sure wonder where that much oil is going?
    I hope it can be figured out for you, that sure is a pretty Trike you have
  4. #44
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Did they check the primary fluid level?
    It is rare, but it does happen that the main seal can fail and let oil from the engine into the primary.
    www.DKCustom.com
  5. #45
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Its funny you would mention the crankshaft oil seal, when HD had to fix my oil migration issue they installed a new crank seal. I wasnt sure what this had to do with the trans migration issue
  7. #46
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Kevin, I didn't mention it but the primary was checked, all good.
  8. #47
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Zammy View Post
    That is good news!
    www.DKCustom.com
  9. #48
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    When crank seal is compromised the vacuum from the engine cooling down can increase the vacuum in the primary, which can pull fluid from the transmission.
    www.DKCustom.com
  10. #49
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    After another 500 miles and it was down another quart, Corporate finally authorized the dealership to tear the top end down. Just got a phone call after hours today that they found some problems, I remember our guy said something about the rings and another part I hadn't heard of. We're going to stop in the dealer on Monday and get the full report, they took photos and forwarded them to the Mothership, we shall see.
    Our dealer at New Port Richey Harley have been great, the main problem has been headquarters getting back to them in a timely manner. They are not happy with the way this has been handled, will keep everyone up to date when we find out more on Monday.
  11. #50
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    I hope they get this straightened out. Damn MOCO can be anal.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
  12. #51
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Some rings were installed wrong, they're going to check the cylinders real well and order new if needed, now to wait and see if there is any part shortages. Sad looking bike with the engine tore down, lol.
  13. #52
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Wow! Crazy to have to go through all that Gary for how much they want for a CVO TriGlide!
  14. #53
    I hope you get new cylinders and pistons, I hope they check the piston oiling jets also
  15. #54
    Oct 2021
    Snow Hill NC USA
    Sad that it wasn’t set perfectly… you think you buy something nice and some crap like this happens, unfortunately it happens to all manufacturers.
  16. #55
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Well, on the road to recovery. Luck on parts Gary.
  17. DKCustoms postbit
  18. #56
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Remember: HD is known as the "Motor Company".
  19. #57
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Yeah, parts are on the way, no need for new pistons or jugs, they have been thoroughly examined with no wear or scoring, I saw the reports and pictures.
    On another note I just wondered if the rings are hand fitted or maybe by robotics from a stack, my dealer didn't know either.
  20. #58
    Usually done by hand with a ring compressor. Anyway that’s how I did it on my VW Beetle..1970’s. My son just did a piston and head on his ATV and used a ring compressor..
  21. #59
    Jan 2009
    MA,
    They say the rings are installed wrong ? so shouldn't all this oil be in the exhaust system ? if not were is it ? No new Jugs or Piston's ? They check the cylinders real good, Hay Billy these Cylinders look good to you They sure Do Bobby change that ring that was upside down We will fill this thing with STP till Hes out of warranty. Thats Harley repair as cheapest as possible, if that dont work then your down for another couple of months . GOOD LUCK Sorry been there before
  22. #60
    30+ Posts
    Aug 2019
    CATSKILL MTS USA
    If that much oil went through the exhaust, they probable should replace the cat and O2 sensors. Or at less make a note of it as oil deteriorates both parts.
  1. Freewheeler gas gauge usage
    By My Turn in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-02-2021, 09:52 PM
  2. oil light came on, low range indicator appeared and the engine died.
    By marnie in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-26-2017, 10:52 PM
  3. Gas usage on my trike
    By TNTriker in forum Harley Trike Conversions
    Last Post: 06-29-2012, 05:31 PM
  4. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
