Likes Likes:  1
Results 1 to 8 of 8
Thread: 2013 Stallion vacuum leak
    Mar 2022
    Pinellas Park, Fl, USA
    Default 2013 Stallion vacuum leak
    Anyone know where I should look for a vacuum leak?
    Quote Originally Posted by gmackie2 View Post
    Gail.. welcome to Trike Talk👍👍
    A little more information on the vacuum leak would be helpful‘But as a start check the vacuum hose’s where they plug in to the nipples sometimes they Swell up (loosen) there..
    Hi Gail, Welcome to Trike Talk
    You can spay some aerosol like carb spray around suspect hoses, if your engine speed increases you have found your leak
    Look closely @ any and all hoses around the intake manifold, use a slight bending motion to check to see if the engine speed increases, if you have cruise control check if it has a hose also
    Hi Gail what exactly is the issue? If it idles but will not accelerate one common problem was the air intake. With age and heat it cracks and allows to puch air in the the MAP sensor does not see. Let us know. there is a solution posted in the Stallion section of the site. If you can not find it or have questions make a post.
    Here is the thread Ted is talking about, this is a common problem with air intakes like this
    https://www.triketalk.com/forum/thre...e-Plenum-Break
    Mar 2022
    Default Gail
    My stallion runs. It idles rough upon acceleration and also lost the vacuum to the power brakes. It sat for a year during COVID times.
    Mar 2022
    Default 2013 stallion vacuum leak
    Where is the vacuum canister located? Anyone know? Maybe there isn’t one.
    Is the hose collapsed? That hose is normally the largest hose and direct vacuum from the intake
    Some times running some Seafoam thru the intake can help cure rough running
  1. Vacuum Operated Air Clutch Help
    By RMartens in forum VW Powered Trikes
    Last Post: 05-26-2021, 02:24 PM
  2. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  3. Stallion antifreeze leak
    By ODDOMAN in forum Stallion Trikes
    Last Post: 08-06-2015, 02:07 PM
Tags for this Thread
