Likes Likes:  1
Results 1 to 12 of 12
Thread: 13 TriGlide reverse enable button engages reverse motor
    Apr 2022
    Brooklyn Ia USA
    Exclamation 13 TriGlide reverse enable button engages reverse motor
    I start my tri glide in neutral. I push the reverse enable button that has the light. The light comes on and also ENGAGES reverse motor!! It doesn’t disengage without turning bike off! Had the reverse motor built twice as I thought is was the problem but issue continues. I also put a new battery in it too. I need help! Thanks.
    Hi Nick, to Trike Talk and your first post
    Take your switch half apart and clean the contacts of the switch with some contact cleaner, see if that helps
    Nick…Welcome to Trike Talk…👍👍..
    Jun 2008
    Lovington, NM, U.S.A.
    Hello and to Trike Talk, glad to have U with Us.
    Retired trike builder
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Nick , what Jack said to start . Ride safe..
    nick welcome
    what Jack said
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Welcome to TT from Ohio. Jack has the right idea to fix. Come back & let us know when fixed. Luck..
    Trike Talk Executive Chef
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Nick…Welcome to Trike Talk....from North Ga. ..
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Member Patriot Guard Riders
    1500+ Posts Ray Paige's Avatar
    Aug 2018
    Bitterroot Valley, MT, USA
    WELCOME ABOARD FROM MONTANA
    Apr 2022
    BRANDYWINE
    Quote Originally Posted by windrider34 View Post
    The reverse on my trike will automatically disengage if I engage the park brake or if I clutch and place the trike in gear.
    Quote Originally Posted by dcodom View Post
    Darrell....Welcome to Trike-Talk.........
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Spray some silicone spray into the reverse button and work it . Could be stuck in the ingauge mode ..
  1. 2013 Triglide Reverse motor
    By MGB in forum Harley Tri Glide
    Last Post: 09-03-2021, 01:38 PM
  2. Replies: 7
    Last Post: 07-23-2019, 03:38 PM
  3. Reverse Motor on ULTRA TRIGLIDE
    By ralco in forum Harley Tri Glide
    Last Post: 03-29-2018, 09:05 PM
  4. Reverse Button Issue
    By hbrogan57 in forum Honda Trikes
    Last Post: 10-20-2012, 03:40 PM
