Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  3
Thanks Thanks:  9
Results 1 to 20 of 20
Thread: Harley Freewheeler - European model with no central headlamp lens - replacement?
    30+ Posts
    Apr 2022
    Veuxhaulles sur Aube, France
    Default Harley Freewheeler - European model with no central headlamp lens - replacement?
    Harley Davidson FLRT Freewheeler Central Headlamp
    The European Freewheeler does not have a central headlamp, unlike the American models featured in their accessory catalogues, but has two “passing lamp” type lamps either side of the central headlamp which, in the European version, is replaced with a circular chromium blanking dome, a bit like a hub cap,
    I do not like this much, and would prefer to replace the “hub cap” with a glass sealed beam unit (not wired in to the lighting circuit) for purely aesthetic reasons.
    In the owner’s manual referring to the central headlamp configuration it says that a single screw holds the outer bezel, and that after removing that, an anti-clockwise turn of the bezel will remove the bezel, revealing the sealed beam unit and the retaining ring.
    My question is, does the European Freewheeler with the “hub cap” in place of the sealed beam unit have a removable bezel, or is the bezel part of the “hub cap” blanking plate? If the bezel is removable, is there a retaining ring behind it that I could fix a sealed beam unit to? If there is no retaining ring behind the blanking plate, is there an HD part number that I could order and fit to allow fitting of a sealed beam unit (albeit non-functioning)?
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by lingone View Post
    Colin….Welcome to Trike Talk….👍👍..
    2019 Tri-Glide.......
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    "Why soitanly" Colin. Those euro passing lamps are cool and I sourced them out and total cost was about $1000.00!! so I went with an police electra glide light bar instead. Your lamp bucket 67700310 is already there. The cover is 61300599 can be removed and a headlamp of your choice installed. Heck hook it up if legal. If a rubber bung isnt in the back of the bucket just drill a hole and add a grommet and run your wires through. But ipen it up- the harness may already be there.
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    I've seen that and always wondered why they're done that way. Any insight to the government thinking on this mandate?
    30+ Posts
    Apr 2022
    Quote Originally Posted by JTJersey View Post
    I am quoting "American V" magazine (a UK publication) which thought it was German legislation, then adopted by the rest of the European Union (EU). Apparently, if you only have a central headlamp on a trike, you have to have sidelamps on the rear wheel mudguards.
  6. #6
    30+ Posts
    Apr 2022
    Quote Originally Posted by Old Road Dog View Post
    Many thanks for your helpful reply.
  7. #7
    30+ Posts
    Apr 2022
    Thank you! I hope to contribute in the future.
    I am English, but moved permanently to France (Burgundy) in 2014.
  8. #8
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Colin's model is listed as HDI England as opposed is to FLRTDom( domestic U.S.) there is also FLRTAus (Australia) and FLRTJapan. Curiously the Aussie model uses a 4 place headlamp connector while all others use a 3 place. Colin could tap a standard connector into blue/white ,blue/yellow ,and black with a new center head lamp.This would give low/ high beam functions.Imagine that coming at you.
  9. #9
    30+ Posts
    Apr 2022
    Default UK Headlamp Regulations for Trikes
    Having checked the Ministry of Transport (MOT) regulations for the UK (which pre-Brexit would be identical to EU (European Union) regulations), any trike over 1300 cm (one metre thirty centimetres) has to have two separate headlamps capable of dip and full beam. As the Freewheeler is 1400 cm wide, it has to have two headlamps. The regulations explain the maximum and minimum distance between them, as well as height above the road.
  10. #10
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Sounds like an arbitrary classification rule by a bureaucrat.
  11. #11
    30+ Posts
    Apr 2022
    Red face European Union Lighting Regulations for Trikes
    I now have a definitive reply from the French Gendarmerie (national police force).
    Here is the answer to your request N° DM_638634 of 06/06/22 16:24 made on the site of the gendarmerie:
    As long as you have the mandatory equipment (the two headlights on each side) and the central headlight is inoperative and does not cause any discomfort, confusion or dazzling of other users, there is nothing to prevent such an installation.
    There aren't really any legal texts at this level and you simply have to conclude that "what is not expressly prohibited is authorized".
    General texts on motor vehicle lighting can be found here: https://www.legifrance.gouv.fr/codes...A000006177087/
    So it is clear that I can remove the blanking plate from the headlamp nacelle and replace it with a (non-functioning) HD glass sealed beam unit.
  12. #12
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    In other words- its left up to the traffic officer that pulled you over. If he suspects your one of the biker types that jingled his unfaithful wife then your in for a bad time. Better to carry a flask of cognac and offer him a belt. Legionnaires operating in our A.O. were issued daily cognac rations. And had Parisien prostitutes flown out to thire T.O.C. .It was strictly off limits to us.On the spot Article 15 if we so much as stepped into thire perimeter. The U.S. Army takes the fun out of everything.
  13. #13
    90+ Posts
    Nov 2020
    Kansas City, MO
    "The European Freewheeler does not have a central headlamp, unlike the American models featured in their accessory catalogues, but has two “passing lamp” type lamps either side of the central headlamp which, in the European version, is replaced with a circular chromium blanking dome, a bit like a hub cap"
    I must be dense because I can not find any picture of this setup and am not able to picture it in my feeble mind.
    I looked on Harley France and the freewheeler looks the same as the US model. Do you have any pictures of this setup?
  14. #14
    30+ Posts
    Nov 2021
    Castle Rock, WA, USA
    Default Euro Freewheeler
    Quote Originally Posted by stratmarshall View Post
    Picture of Euro Freewheeler.
    US Freewheeler does not have the lightbar with the two driving lights.
  15. #15
    30+ Posts
    Apr 2022
    Default European Headlamp Setup
    Quote Originally Posted by Evets View Post
    Here is what the European Freewheeler headlamp setup looks like, with a blanked off central headlamp.
  16. #16
    50+ Posts
    Aug 2022
    Independence, mo usa
    Looks weird. They kinda stuck them out there a ways didn't they? I wonder what it would look like in front of a shield or fairing?
  17. #17
    30+ Posts
    Apr 2022
    Default European Headlamp Setup - Installing a central headlamp
    I have ordered the US model central headlamp (68345-05A), retaining ring (68050-93A) and bezel (68051-08) so I can have a (non-functioning) central headlamp.
    I can confirm that my European Freewheeler has no wiring at all in the headlamp shell, but as I was not going to wire it in this is not an issue.
    I will let you know how I get on when the parts arrive in France, and also post a picture.
  18. #18
    30+ Posts
    Apr 2022
    Here are the photographs of my successful conversion from the European blanking plate ("hub cap" or dustbin lid") to the American version headlamp.
    The conversion used the parts I listed above.
    The blanking plate photograph is not my trike, the headlamp version is my bike.
  19. #19
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Is this fake headlight in the center just a Trike thing or do two wheelers have to do it too?
  20. #20
    30+ Posts
    Apr 2022
    Just a trike thing in the European Union (EU). Any vehicle over 130cm (1 metre 30 centimeters) wide has to display two headlamps (or one central headlamp and white lights facing forward on each rear wheel arch in the case of trikes). I think Germany is very tough on this rule.
    HD clearly thought adapting two passing lamps to be headlamps and blanking off the central headlamp was the way forward.
  1. European model Freewheeler
    By cobalt07 in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-06-2022, 05:53 AM
  2. Seeking advice on cataract replacement lens
    By BillR in forum General Discussion
    Last Post: 07-21-2018, 05:20 AM
  3. New Custom Dynamics LED headlamp
    By Hrolfr in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-06-2016, 09:06 AM
  4. Turn Signal Replacement lens
    By Jolie in forum Suzuki - Kawasaki Trikes
    Last Post: 05-24-2015, 06:38 PM
