Likes Likes:  2
Results 1 to 6 of 6
Thread: 2010 Tri Glide Air suspension
    Apr 2022
    BROWNSVILLE
    Default 2010 Tri Glide Air suspension
    I just bought a 2010 Ultra Classic, Tri Glide. The guy I bought it from didn't know how to do anything on his trike. So now, I have a question, I hear I need to check the psi on my air suspension, but how do I do it? I have a HD pump to do the job, but I don't even know where to look for the fitting. The man before me had it for 12 years and only put 5126 miles on it.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Welcome Mark, try looking under the right side cover. there should be a air valve in the upper right hand corner.
    Mark.....Welcome To Trike-Talk.........And yes as Steve says, Theres an air valve under the right side cover....Is the air pump you have an No-Loss air pump, I ask cause with a regular pump you will lose air when you remove it from the valve and your readings/psi's will be way off.....
    Hi Mark, to Trike Talk
    The schraeder valve should be behind your RS cover near the top RH
    You have the HD pump, that is a good pump and does not bleed off air when you disconnect it
    Have a fun day riding
    welcome mark
    150+ Posts KJB's Avatar
    Oct 2014
    NE WI & SW FL
    Somebody offered this tip long ago so I can't take credit for it but it continues to serve me well. I bought the valve stem extension in the link below and have the end of it sticking out from behind the cover. It's barely visible but it makes checking air pressure much easier without having to remove the right side cover. I have never experienced a leak from the extension.
    Valve Stem Extension - 42300009 | Harley-Davidson USA
  1. 2010 tri glide/ 2010 street glide
    By roadkill in forum Harley Tri Glide
    Last Post: 07-05-2023, 09:55 PM
  2. Motor Trike Air Suspension Air Bag Replacement
    By bassfisher in forum Honda Trikes
    Last Post: 04-23-2023, 11:23 AM
  3. Low mileage 2010 tri glide trike street glide
    By jwkhd1 in forum Harley Tri Glide
    Last Post: 09-20-2012, 07:54 AM
  4. Tri Glide Legend Suspension
    By trikermutha in forum Harley Tri Glide
    Last Post: 04-11-2011, 10:02 AM
