BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  1
Results 1 to 9 of 9
Thread: wheel weights
    40+ Posts
    Nov 2017
    Kettering Ohio USA
    Default wheel weights
    Wanting to use balancing beads how much in front wheel how much in rear tires 2017 harley trike
    Thanks for info
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    I'm running 2 oz in the front on my 19 Tri Glide and 3 oz in the rear. I've used the bead balancing system when I had my bike shop balancing many many tires, never had a problem.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    300+ Posts
    Dec 2014
    florissant
    The problem with the beads is if moisture is introduced into the tire from adding air they tend to clump and no longer do their job of balancing the wheel. This is the reason i use Ride-On and you get the added benefit of puncture protection.
    hardheaded
    Oct 2018
    Ramseur NC USA
    I have an excellent moisture filter on my compressor. All I know is I run Dyna beads for many many years and never had a problem. Put them in many customer bikes and never heard a problem from them. That's all I can tell you
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by payzac View Post
    Thanks for info
    use what manufacturer says!
  6. DKCustoms postbit
  7. #6
    Oct 2018
    Ramseur NC USA
    Thanks for info
    Manufacturer's website says 2 oz in the front and three in the rear on trikes with tires of that size.
  8. #7
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Thanks for info
    https://www.triketalk.com/forum/thre...699#post887699
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  9. #8
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I've heard such good reports on balancing beads I tried them when I replaced my front tire a few months back . . . but with poor results. Had a slight but noticeable vibration right about my preferred cruising range speed. Not sure exactly what might have caused this. I know they caution about getting any tire rim lubricant inside the tire which could get the beads damp and cause them to clump up. I suspect this might have been the problem but rather than fight it I just had them removed and the tire balanced the old fashioned way with weights.
  10. #9
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Only time I’ve ever have bad results with either beads or rideon was when I forgot to take the weights off. Or when the installer complained about my rim being all gunned up with the ride on gel.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
  1. Front Wheel--Rear Wheel
    By drumdoctor in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-06-2015, 12:45 PM
  2. Rear Tire Balance Weights
    By desertclassic in forum Harley Trike Conversions
    Last Post: 07-16-2015, 08:57 AM
  3. Replies: 5
    Last Post: 12-08-2014, 01:03 AM
  4. 2 wheel to 3 wheel and back again
    By dollysgizmo in forum General Discussion
    Last Post: 04-03-2013, 08:03 PM
  5. Swivel-Wheel Trailer behind 5th wheel
    By Doc Dyna in forum Trailers / Campers
    Last Post: 10-16-2012, 10:04 PM
