Likes Likes:  1
Results 1 to 4 of 4
Thread: Hot battery .
    20+ Posts
    Jan 2022
    Wellsville NY USA
    Default Hot battery .
    Has anyone found that their battery gets too hot being tucked in away from the air stream? Is a cooling fan ever needed for battery boxes?
    Quote Originally Posted by bgarrison54 View Post
    You have a very good point, just like anything electrical, cooler is better
    Electricity by nature creates heat, batteries can and do explode from too much heat
    A quick check of a charging system is in order, if too much voltage is being generated by a sticking regulator it can easily create an over charge= more heat
    Personally I think it’s a non-issue….
    I haven’t had any reason to check any battery for heat.. Before the advent of smart chargers you would have to check that the battery doesn’t get too hot (Over charged) when you put it on a regular charger for long periods of time… But those days are long gone ..
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default Hot Battery
    Usually caused by over charging or a high amp draw . Or just too small for the job .
  1. 2015 HD freewheeler. ...Hot hot!
    By tiffany in forum Harley Trike Conversions
    Last Post: 10-07-2021, 10:26 AM
  2. How hot is hot?
    By 33trikes in forum VW Powered Trikes
    Last Post: 07-23-2016, 05:53 PM
  3. hot tool sale get em while they are hot
    By stacebg in forum General Discussion
    Last Post: 10-13-2014, 04:46 AM
  4. hot hot hot brings storms
    By oneup in forum General Discussion
    Last Post: 01-07-2014, 06:35 AM
  5. hot hot hot
    Last Post: 01-06-2014, 04:25 PM
