Likes Likes:  5
Results 1 to 7 of 7
Thread: Front wheel and tire swap
    20+ Posts
    Jan 2022
    Wellsville NY USA
    Default Front wheel and tire swap
    How do I adapt a car rim to fit on a Harley front forks and axle
    First I would like to know, why would you want this?
    I see many machining steps to do this, let alone what the cost factor might be
    Have you figured out axle and bearing parts, how or who will make the centering hub?
    How and what brake parts will be needed
    20+ Posts
    Jan 2022
    Wellsville NY USA
    Default Front tire swap
    I thought it would involve a lot of machine work. Hoping maybe someone has developed kit for such a swap. I see car wheels used on some trikes but I can't see how the wheel gets a proper hub for motorcycle use.
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    You could check with Buchanan wheel and spoke. They used to have a 15" rim and spokes you could lace to a Harley hub. I had a 15" wheel on the front of my trike for a while. i didn't like it because the tread was flat, and when you turned it would get up on the shoulder of the tire.
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    That's one of the problems. Unless you have a center hub steering frontend, kind of like a car front suspension, the flat profile tire will fight you to stay flat on the ground. It will be harder to steer than a fat round profile motorcycle tire.
    20+ Posts
    Jan 2022
    Wellsville NY USA
    Default Thanks
    Thanks for the input on car wheel/trike wheel swap .Good points that opened my eyes to possible problems.
    200+ Posts ItBeMe's Avatar
    Sep 2017
    Carrollton Ga
    If you want to run a car tire on the front just find a tire that will fit. I did and love it.
Size:  1.03 MBName:  CFE92C2D-7787-48E0-800E-73930D652300.jpg
  1. 16x5.5 inch rear wheel converted to dual dics front wheel
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2022, 08:29 PM
  2. MotorTrike wheel swap.
    By Wildbill55 in forum New Member Introductions
    Last Post: 01-17-2021, 03:51 PM
  3. Front Wheel and Tire
    By Hank62 in forum Harley Trike Conversions
    Last Post: 04-24-2017, 07:52 AM
  4. Front wheel swap?
    By stroker 23 in forum Harley Tri Glide
    Last Post: 09-27-2015, 03:07 PM
  5. Front Wheel--Rear Wheel
    Last Post: 08-06-2015, 12:45 PM
