Likes Likes:  10
Thanks Thanks:  12
Page 2 of 2 FirstFirst 1 2
Results 21 to 28 of 28
Thread: Floor jack cross beam to lift rear of Tri-Glide
  1. #21
    Quote Originally Posted by ron49th View Post
    Looking at Kevin's Trike pic - do you see any problem using the first cross member [nearest the bumper]? - the second in cross member is closer to the reinforced right angle braced frame, may be a better choice, as it closer to the load and reinforcement. Which are you using? Another thought, if you use the second cross member for jacking and the first member for the stabilizing jacks. [ would you have enough room to place the stabilizing jacks and then remove the floor jack?]
    Ron
    Ron, my Freewheeler has the same frame as a Triglide
    I have used the rear cross member to jack it up, I place jack stands under the lower shock mounts or under the swing arm depending on what service I may be doing
    I hope this helps
  2. #22
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Ron
    I've thought about that but don't really see any problem. I've jacked it several times this way with no problem.
  3. #23
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Ron
    We've used both with no problems...been doing this for over a decade now...zero issues. AND, we do it a lot. Our last round of testing for the development of the NexGen Shocks had us jacking up the TG well over 100 times....probably closer to 300 times.
    The front crossmember is closer to the frame right angle, and there is less leverage on the frame. The rear crossmember has a VERY HEAVY solid bar of steel sitting in the crossmember channel, giving it some serious extra rigidity. The whole frame is over engineered and strong...either one is fine.
    www.DKCustom.com
  4. #24
    40+ Posts
    May 2016
    West Coast BC Canada
    Thanks Kevin - your every day functional testing results, speak for themselves.
    Ron
  5. #25
    100+ Posts
    Apr 2022
    Bridgewater, New Jersey, USA
    I have a hitch on my trike so I came up with this. The bar sits about an eighth of an inch below the mounting brackets so I had to add the shims(?) Notice how the jack is off center. That keeps the load centered so it lifts level. It does teeter while up so if doing ANY work you have to use jack stands as soon as its where you want it.
  7. #26
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I've been using the J&S trike lift since 2015
    IBA#61162
    PATRIOT GUARD
    USMC
  8. #27
    Aug 2020
    Oskaloosa, IA, USA
    Hey Smitty I have that same jack/crossbeam setup. It doesn't quite clear the stock exhaust so I just drive the rear wheels on a 2x6 or 2x8 piece of scrap lumber, then it will clear.
    I do like Ultra's crossmember idea though... probably gonna try that.
    Quote Originally Posted by SmittysTrike View Post
    I just got one of those for just lifting the trike. Wont fit under the trike at all! Maybe it will if the lift kit was installed but as it sits from the factory it wont. And I do have a new low profile jack. If you look at the way the guy on you tube has his jack you'll see he's using it after its on ramps which will work to get the ramps out.
  9. #28
    100+ Posts
    Apr 2022
    Quote Originally Posted by JeffIA View Post
    Didn't think of doing that. Good idea!
  1. 2021 Tri Glide Ultra Hi Beam Headlight
    By TexasBilly in forum Harley Tri Glide
    Last Post: 08-26-2021, 10:48 AM
  2. Question on storage on cement floor without a jack
    By Trampas in forum Harley Tri Glide
    Last Post: 09-15-2016, 01:07 PM
  3. Floor jack lifting point? 03 with MotorTrike (Spyder)
    By Metal_Bob in forum Honda Trikes
    Last Post: 08-22-2016, 07:48 PM
  4. floor jack
    By geraldlanc in forum Stallion Trikes
    Last Post: 04-22-2013, 06:54 PM
