JTJersey2JTJerseyHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey2rhino 2Harley Freewheeler /...Removing Trim Around Oil Cooler
Jarhead17751Jarhead1775Harley Freewheeler /...paint job
AriNV12AriNVNew Member Introduct...New to trike
AriNV12Phu CatNew Member Introduct...New to trike
AriNV12ol' schoolNew Member Introduct...New to trike
AriNV12hardwickbvNew Member Introduct...New to trike
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
TomyJ7TomyJSidecar ForumHackHer
Speed Bleeders
AriNV121dn5upNew Member Introduct...New to trike
AriNV12SullyNew Member Introduct...New to trike
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV12trike ladyNew Member Introduct...New to trike
AriNV12GorillaNew Member Introduct...New to trike
AriNV4GorillaCan Am Spyder Trike...I'm a total newbie ... Is the Spyde...
Grandpot9Papa ZookHonda TrikesFront tire?
Grandpot9tourmanHonda TrikesFront tire?
AriNV12Marc HNew Member Introduct...New to trike
Burnerboy4pawsRoadsmith Trikes
Too Pa Pa Zook
AriNV12Uncle FesterNew Member Introduct...New to trike
Jack Klarich2Jack KlarichGeneral DiscussionMY first guitar
Jack Klarich2ZammyGeneral DiscussionMY first guitar
Too Pa Pa Zook
Hdsteal4Jack KlarichSuzuki - Kawasaki Tr...Completed MS Trike Pics
Noodles1078Jack KlarichHarley Freewheeler /...Very Nice Gloves
Noodles1078Papa ZookHarley Freewheeler /...Very Nice Gloves
Noodles1078LadyonaMissionHarley Freewheeler /...Very Nice Gloves
Hdsteal4oldschoolSuzuki - Kawasaki Tr...Completed MS Trike Pics
oldschool6oldschoolHarley Trike Convers...Any Completed DNA Trike Kit Owners?
Jack Klarich1Jack KlarichGeneral Harley ChatDiagnostic Trouble Codes for Harley...
Likes Likes:  5
Thanks Thanks:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
Thread: Electrical Gremlin(s) ???????
  1. #21
    30+ Posts
    Oct 2021
    UK
    Default Electrical Gremlins (???????)
    Latest update…….. Tried all the kind suggestions made - Thank you.
    Disconnecting battery for couple of hours had no effect. I “think” I can hear the strange “squeak” when the bike powers up along with the fuel pump priming. Checked the blue wire from the grey multi pin plug under the rear of the seat to the J3 pin of the BCM plug and there is continuity there.
    Then decided to use my multimeter to measure voltage across the blue and black wires of each rear light unit and the light unit in the tour pack and, to my great surprise, I have just under 5 volts at each of the light cluster and tour pack plugs. So do the LED’s in each of the driving rear lights need 5V to operate? And if one LED bulb has gone or is faulty would that cause them all to not work? I am assuming that there are NOT separate LED’s for rear driving lights and rear brake lights?
    Bob
  2. #22
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    The Bosch invented canbus system dosnt use a full 12 volts at load. So 5v sounds about right.Set your meter to milliamps- it should show above 120 milliamps or code DTC B2106 will show.Above 3 amps B2169 will show. Above 10 amps and B2109 will show. Im thinking your lamp is bad. Go to the auto parts store and get a 5v+ LED lamp like used on dash/ marker/ accessories etc. Probably under 10 bucks. Makeup a jumper lead to bypass running lamp. If it lights then your running lamp is suspect.
  1. Do you have a Gremlin Bell ?
    By Sully in forum General Discussion
    Last Post: 12-23-2016, 03:22 PM
  2. Question on the gremlin bells.
    By Mike D. in forum Honda Trikes
    Last Post: 01-23-2012, 11:24 PM
  3. electrical problem, volt meter in 12v range
    By silverdevil in forum Stallion Trikes
    Last Post: 03-12-2010, 11:50 PM
  4. Electrical Problem - Blowing Fuse
    By patriot in forum Honda Trikes
    Last Post: 10-15-2009, 08:50 AM
  5. Electrical Woes
    By Ozarkryder in forum Honda Trikes
    Last Post: 06-15-2009, 08:54 AM
