SSpoon1SSpoonNew Member Introduct...Hello from VA
Likes Likes:  11
Thanks Thanks:  3
Results 1 to 20 of 25
Thread: Oil showing completely full when cold?
    Jun 2022
    Racine, WI, USA
    Default Oil showing completely full when cold?
    What should I do if my oil stick is showing completely full when the engine is cold? 2015 Freewheeler
    Quote Originally Posted by McJohnson57 View Post
    Michelle welcome to Trike Talk..👍👍
    On the oil did you just have the oil changed?..
    Hi Michelle, to Trike Talk
    If you have an old Turkey baster you do not care about, stick it in the oil tank and suck some out
    Too much oil is not a good thing, it will cause extra drag on the flywheels and you will end up with oil carry over into the intake
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Welcome to the forums Michelle, what Jack suggested is what works, I use a turkey baster also when necessary.
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Harbor Freight sells a suction gun for $13.00. Way better than a baster that tends to dribble out- at least thats been my experience.
    Quote Originally Posted by Old Road Dog View Post
    Yes, that does work better with very little dribble
    I said a baster only because most homes have one in the kitchen
    I think everybody’s getting ahead of themselves what does completely full mean when “Cold”.. Is the level on the full mark or a half inch above the full mark?? the oil should be checked when it’s warm or hot ….Not cold.. my advice to a newbie would be to the check when it’s warm or hot before you decide take any oil out…
    100+ Posts W3JNP's Avatar
    Nov 2016
    Reading, PA
    Picked up my 2016 Freewheeler last August and have done 3 oil changes since that time. The manual says 4 qts. of oil but it is really more like 3.5 or you will be overfull.
    If you have to much you can get some out as suggest with a turkey baster, oil transfer pump or Mityvac.
    2008 Stallion
    Reading, PA 19606
    Nov 2016
    Reading, PA
    See the attached from my 2016 Freewheeler Owner's Manual.
    2008 Stallion
    Reading, PA 19606
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    3 weeks ago I installed the oil temp sensor into the drain bung for the new Dakota Digital speedo. If your quick you can install it without losing much oil they said. We do it all the time they said. But I dropped the sensor. Whats the use might as drain the pan all the way. Cold fill was over the mark so I sucked some out. Went on a 20 mile shakedown ride consisting of two lane and four lane. Oil temp at end of ride was 172 degrees. Hot check showed low so I added oil. Go figure.
    It seems like the OP Is a one hit poster..??
    This, and those that do not introduce them self ,rather jump in asking for help. Then they disappear
    I don’t know squat about computer codes but maybe there should be someway a new member that wants to make their first post it automatically /mandatory goes to the introduction thread ?
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I guess you can do what you want. But it's not like we're being flooded with new members. Just sayin.
    750+ Posts
    Jan 2010
    east windsor ct
    aren't these engines dry sump??
    750+ Posts
    Jan 2010
    east windsor ct
    these are dry sump engines(unless they changed)which means the oil is in a tank NOT the crankcase so the will be no extra oil to create drag
    Yes, but too much oil cannot be returned to the oil pan fast enough, it will collect in the case and push out thru the breathers in the heads
  19. #19
    750+ Posts
    Jan 2010
    east windsor ct
    please explain
    why would the engine get more oil if there is some extra in the tank... i would think the pump will pump x amount of volume no matter how much is in the tank... and i dont see how any oil could be going to the sump by gravity..
  20. #20
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    I looked and looked but I cant find the oil tank. I think my M8 has a manufacturing defect. Maybe I'll write the MoCo.
  1. How Cold is too cold to take a ride
    By NJtony in forum Harley Freewheeler / Road Glide 3
    Last Post: 12-30-2021, 03:16 PM
  2. Cold, What Cold.
    By Sully in forum Military & Veterans
    Last Post: 01-02-2018, 08:23 AM
  3. Change Radio Completely?
    By J-Bear in forum Stallion Trikes
    Last Post: 09-28-2015, 03:05 PM
