Thanks Thanks:  1
Results 1 to 9 of 9
Thread: Klunk Sound on Rt Rear
    1750+ Posts
    Dec 2010
    MD
    Default Klunk Sound on Rt Rear
    When I go over a "nasty" piece of road or manhole cover, I get this "klunk" noise usually on the right rear side of the trike. It is an 05 Lehman Monarch II. It has never done it before, I guess old age. Have never done any adjustments to the 1 up, 2 up. Since I don't have the manual for the trike any ideas on what I can do?
    "Those who hammer their guns into plowshares will plow for those who do not" Thomas Jefferson
    "Ignorance can be educated, crazy can be medicated, but there is no cure for stupid."
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    I'd start looking for the simplest to fix first. Broken shock, worn bushings, worn U-joint, worn out wheel bearings, etc. Then if all the easy stuff checks out it gets more difficult. It could be a broken bracket holding the body on the trike frame (I had one). Unfortunately, this requires a bit of work removing the body to find and fix. Good luck..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    Start with a static bounce test of the rear of the trike
    Push down hard on the rear 1 side at a time, do you hear anything?
    If you do it is time to jack it up and check further
    What you describe sounds like a shock problem IMO
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    Just an idea take everything out of the trunk and go hit that same spot in the road.
    2019 Goldwing CSC
    1750+ Posts
    Dec 2010
    MD
    Quote Originally Posted by woody View Post
    Thanks Woody, nothing in the trunk and hatch except my hat. It is okay with normal bumps just the ones that jar your molars.
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    How many miles on your Lehman?
    1750+ Posts
    Dec 2010
    MD
    Quote Originally Posted by Mick View Post
    53,330 miles it is an 05
    Feb 2008
    Midwest
    A few things you can check out with your mileage. See if the main Lehman shock is leaking oil or seeping this is an indication of a blown shock. While youre there check out your spring setting. Jim and Al Timm told me to keep it on the middle setting unless my passenger was a good sized person or I was towing a trailer. You can also check the stop blocks or bump stops for the swingarm.
    https://www.manualslib.com/manual/93...page=18#manual
    I hope this isnt an issue you have but take a flashlight and check the subframe under the body from underneath. Mine was making a noise about 10 years ago and I found the subframe and swingarm cracked in 5 places.
    But I would check out the bumpstops 1st.
    1750+ Posts
    Dec 2010
    MD
    Default Looking for Someone in Maryland Area
    Need to get someone who is a Triker that would be willing to take a look at the "Klunk" in my 05 Lehman Monarch II. I have lost my WVa good guy Jim "Lee H. Mann". who did all the work on my Trike. Not looking for a freebee. I know how the Honda Dealerships are not really willing to work on Trikes unless they sell them and they are few and far between. Ten years ago, I would have tackled the problem but those days are long gone. Any input appreciated. Thanks to all who have responded.
  1. Replies: 2
    Last Post: 09-20-2019, 02:50 PM
  2. Rubbing sound on Right Rear 2009 Champion IRS
    By ColoNavy in forum Honda Trikes
    Last Post: 09-06-2016, 09:39 PM
  3. Radio, Music or sound of the wind?
    By Chuck in forum General Discussion
    Last Post: 12-30-2012, 09:51 PM
  4. Chirping sound.
    By Spirit Warrior in forum General Discussion
    Last Post: 06-13-2010, 11:57 PM
  5. Does this deal sound legit?
    By WindyOne in forum General Discussion
    Last Post: 01-18-2010, 11:28 AM
