Likes Likes:  3
Results 1 to 4 of 4
Thread: Lifting 2014 CSC Viper to replace front tire
    Jun 2021
    Reklaw, Texas USA
    Default Lifting 2014 CSC Viper to replace front tire
    I know will get some responses for this thread. I looked and did not find where anyone had said how to raise the front end enough to front tire off. I have a Trike Lift. And a Handy scissor jack I have used for years to lift bikes to change tires. This is our first trike. So dont want to break anything.
    Looks like only spot is on the engine block, but not sure.
    Any help is appreciated.
    Jimmie
    Jan 2009
    MA,
    Quote Originally Posted by Hangten9595 View Post
    Jimmie
    Gold Wing ? When I had mine I made a step ramp out of 2x4 I put a piece of wood under the front of the motor and used my floor jack to jack up.
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    You just need to put a floor jack under the engine block and raise it up like you were considering. That's how I have done it many, many times. I have a low profile floor jack that I picked up at Harbor freight and it works great. I actually did just this last year while at a campground because I wanted to finally get my Avon Cobra Chrome Trike tire installed and the front tire I had was worn down pretty good.
    I will usually put towards the middle of the engine block. Just make sure not to go too far back or you might accidentally start lifting under the coolant reservoir and that would be a bad mistake.
    One thing I've noticed is the CSC trikes end up sitting just a little lower than pre conversion so it is a bit harder to get a jack under there especially if you have the floorboards.
    90+ Posts Sandman1's Avatar
    Jan 2021
    Palm Harbor, Florida, USA
    Cool What PWHover said
    Yupp, I lift mine for oil changes just as mentioned/described by pwhover.
  1. Lifting a CSC with irs
    By geraldlanc in forum Honda Trikes
    Last Post: 03-04-2022, 10:28 AM
  2. When to replace front tire?
    By brianl in forum General Discussion
    Last Post: 01-08-2021, 12:28 PM
  3. Replies: 1
    Last Post: 05-07-2018, 07:10 AM
  4. Replace or not to replace
    By jimmer116 in forum Harley Tri Glide
    Last Post: 09-10-2017, 05:37 PM
  5. Lifting Front of Goldwing Trike
    By Muleskinner in forum Honda Trikes
    Last Post: 09-20-2010, 09:13 AM
