Likes Likes:  7
Thanks Thanks:  7
Results 1 to 17 of 17
Thread: 2019 CSC/Goldwing rear diff failure at 8000 miles!
    40+ Posts Wing'n It's Avatar
    Sep 2019
    Eaton, Ohio, USA
    Default 2019 CSC/Goldwing rear diff failure at 8000 miles!
    Went on long ride today and my trike started making weird noises, mostly when coasting like downgrade. More miles in started getting some vibration felt clear up into the handlebars. Decided I had better get this checked out, detoured off route and went to a buddy house where we could check it out. Suspected the driveshaft first but it appears to be fine. Put the rear end up on blocks with both rear tires off the ground and when you spin either side it sounds like rocks in a washing machine! Damn this is not good! Trike has right at 8100 miles on it. Now I'm gonna loose it during peak riding season and we had a 4 day ride coming up fathers day weekend with hotels booked! I'm not happy! Calling dealer in the morning to see what can be done with it.
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    keeping an eye on this I'm interested in what happens. I changed my differential fluid at 5000 miles and the oil that came out didn't look bad.
    2019 Goldwing CSC
    Sep 2019
    Eaton, Ohio, USA
    I changed mine at around 3000 miles and the oil looked good. We dumped the oil that was in it yesterday and while it looks ok there did seem to be a trace of "metallic" in it. I'm pretty sure it's the output shaft bearing on the left side, if you turn the axle shaft slowly while wiggling the shaft/CV joint there is loose and tight areas. I looked on the net to see if I could find a parts diagram for the diff to see if those are ball bearings or tapered bearings. I'm betting ball bearings by the early failure.
    I have a video of the noise and it's horrific sounding, can't seem to post the video on here.
    90+ Posts Sandman1's Avatar
    Jan 2021
    Palm Harbor, Florida, USA
    Gee, so sorry to hear of you having an issue with the CSC conversion. Hopefully you can get it taken care of to enjoy your planned trip. Give Will @ CSC a shout out. I am confident if you can get avideo of the sounds/visual he will provide you guidance. 5-year warranty on their kit. Hopefully you have a CSC dealer-installer near you. Do let us know what you find out.
    I had my 2018 DCT Tour converted last year, I replaced the rear drive oil as recomended by CSC and the rear drive oil was dark no signs of metal. Replaced with CSC suggested oil. No issues to date.
    Jul 2012
    Talladega,Al 35160
    you said something about calling your dealer what did they say? I think I would call CSC direct from what I have heard they are good to work with.
    2019 Goldwing CSC
    Sep 2019
    Eaton, Ohio, USA
    Called the dealer and while they was helpful there is no way they can provide any service in time to save my trip. The dealer also called Will at CSC and They said there has been no know issues with the rear diff's. Even though it's clearly under warranty I may attempt to dig a little deeper into it and see if possible to save my weekend, time is running short and parts may be an issue if it comes to that. I was told that if I go into it CSC want's me to take plenty of pictures on what I find as they are curious as well. The dealer suspects outboard wheel bearing/hub not the diff.
    If anybody on here knows how to post that video let me know as I would like some input on it.
    Jan 2009
    MA,
    Quote Originally Posted by Wing'n It View Post
    I had a outboard bearing go my 2008 GL 1800 CSC The wheel bearing From the dealer it a lot of money, I went to NAPA we look at 50 different bearing's and found it to be the same as 2006 chevy cavalier front bearing, was not a big deal to changed, pull the wheel , the caliper, rotor, the big nut on the axle, and three bolts on bearing , at that time the bearing was around $100.00. I can look for the part number at home later today if you want it, mine went around 6000 miles .
    Sep 2019
    Eaton, Ohio, USA
    I tore the bike down this morning hoping to get a solution and save the ride. Well ROAD DOG, the wheel bearing/hub is indeed the problem. Once it was removed from the bike it makes a horrible grinding noise. Pretty sure it was assembled with no grease in it as there is dry black dust coming out of it! I know this is not a CSC part so no blame towards them but better quality hubs on a bike this expensive would be nice. I could easily see one of these locking up and causing some serious issues. I'm in this deep now so it only makes since to tear down and check the other side. Not leaving till AM Saturday morning so if I can get a hub I should be able to make it.
    Jan 2009
    MA,
    Do you have the hub out ? Can you post a picture of it ? I can tell you if its the same ? go to a auto parts store and buy one give them the bill
    Jan 2009
    MA,
    Heres A napa number BR930028k, advance auto parts Number 91-45065 The advance bearing looks better quality in the picture My cost is $82.00 both places. Type in advance Auto Parts And the part # it will come Up
    Sep 2019
    Eaton, Ohio, USA
    Yes its out, will post pic later. I did some research on the info you posted and it looks exactly the same. GM stopped the Cavelier in 2005 and replaced it with the Cobalt in 2006 but the 05 Cavelier is a match. My local Oriellys has on in stock for $92 with 3 year warranty. My dealer said they should reimburse parts prices.
    Jan 2009
    MA,
    Do them Both
    Sep 2019
    Eaton, Ohio, USA
    Do them Both
    Left side replaced and trike is back to normal,... hoorah! I have another hub on order to keep back as a spare.
    Jan 2009
    MA,
    Thats Great ! Now go ride and Enjoy
    Jan 2009
    MA,
    It was a 1986 Cavalier Not a 2006
    Sep 2019
    Eaton, Ohio, USA
    Rode about 50 miles last night and all is good. No noise and no vibration running just as new again. Leaving in the morning for big 4 day ride, oh it's gonna be hot!
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Thanks for the post, it was very informative!
    Also thanks for the part numbers.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
  1. CSC Viper Diff Oil Change Tips ??
    By weightdn in forum Honda Trikes
    Last Post: 03-30-2019, 09:15 PM
  2. CSC Rear Diff Seal
    By rhino65 in forum California Sidecar Trikes
    Owners Forum
    Last Post: 12-30-2016, 06:36 PM
  3. 2014 E-Brake PAWL failure @ 13,800 miles
    By HDB0B in forum Harley Trike Conversions
    Last Post: 08-26-2015, 10:12 PM
  4. solid rear diff. or independent ?what say you??
    By irmagoo in forum General Discussion
    Last Post: 01-05-2013, 08:20 PM
  5. A/C failure at 2,500 miles
    By Road Runner in forum Stallion Trikes
    Last Post: 05-19-2009, 10:55 AM
