Likes Likes:  5
Thanks Thanks:  3
Results 1 to 18 of 18
Thread: Horn and reverse not working.
    30+ Posts tinner12002's Avatar
    May 2022
    Lafayette
    Default Horn and reverse not working.
    2 week old trike and went to Honk the horn 4-5 times today then it quit. Made another stop and checked reverse and its not working either. Haven't had a chance to check fuses but thought I'd see if anyone else has experienced this on a Harley and what their fix was.
  2. Roadsmith banner
  3. #2
    Quote Originally Posted by tinner12002 View Post
    Also check the the breaker for the reverse under the panel right side cover...
    And if its extended push it in till you hear a Click''
  4. #3
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Which trike are you riding - make, model and year? All of this may be helpful is addressing your concerns
  5. #4
    May 2022
    Lafayette
    Quote Originally Posted by cycle7447 View Post
    Thought my profile pic would show up but guess not. Its a 2012 Harley Ultra Limited with a 2 week old Roadsmith kit.
  6. #5
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    After breaker reset , if it pops again , I’d return to kit installer for possable shorted out circuit.
    May 2022
    Lafayette
    Was working fine half of the day, quit while on the way back home.
    May 2022
    Lafayette
    I have noticed its charging at a higher rate than it used to....at about 14.3 when at speed.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Had my volt meter replaced twice due to false readings . Then I checked charging rate on system with a real digital meter. All was ok at 14.3 volts . Fully charged battery at 12.7 volts standing.
  10. Roadsmith banner
  11. #9
    May 2022
    Lafayette
    Looked under both side covers and found no resettable breakers.
  12. #10
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Under Right side cover . See owners manual.
  13. #11
    May 2022
    Lafayette
    Again, not seeing anything about a breaker in my manual, even on the pics showing everything, no breakers, only fuses and relays. Right cover is only hyd controller for anti-lock system.
  14. #12
    I Guess Road Smith uses a different system on their reverse so Call to Road smith might be in order🤔?.. when you get it sorted out let us know..
  15. #13
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Being it started as a 2 wheeler , there is no need for a reverse breaker . The reason it’s not found . But after the conversation there should be some other added circuit for the reverse by road smith . Or it was added to the horn circuit
  16. Roadsmith banner
  17. #14
    It is the horn button that actuates the reverse
    I would be looking @ the P and A fuse in the fuse box first
  18. #15
    250+ Posts
    Jan 2012
    oz
    Bring it back to the installer, Why fool with it?
  19. #16
    May 2022
    Lafayette
    Got it ironed out, apparently a connector had worked loose up under the back end, just enough that it lost connection. After talking to them they walked me through some trouble shooting that narrowed it down. I'll need to get it somewhere with a lift so i can get under it to make sure it doesn't happen again. Appreciate all the comments trying to help!!
    2012 Ultra Limited with RoadSmith trike conversion
  20. #17
    250+ Posts
    Jan 2012
    oz
  21. #18
    Sep 2016
    Springfield, Mass. USA
    Suggestion: About a lift, cut a 4x4 board a foot long, three times, then use a jack to lift up your rear end wheels and place a cut board under each wheel, then lift up your front end a place the other cut 4X4 under that wheel............. NOW YOUR UP FOUR MORE LEVEL INCHES, that gives you more room to crawl under your trike...
  1. Horn not working.
    By Old Hippie in forum Harley Tri Glide
    Last Post: 03-09-2022, 02:43 PM
  2. Reverse not working
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 09-04-2018, 04:15 PM
  3. Reverse Not Working on 2015 Tri Glide
    By sdavidson in forum Harley Tri Glide
    Last Post: 09-20-2015, 04:55 PM
  4. 2010 TriGlide Reverse Not Working
    By eforman48 in forum Harley Tri Glide
    Last Post: 05-01-2015, 07:39 AM
  5. 2009 Reverse not working
    By tri glider in forum Harley Tri Glide
    Last Post: 08-14-2012, 04:19 PM
