Likes Likes:  2
Results 1 to 7 of 7
Thread: Lehman Trike Renegade model electraglide rear brakes lock up
    User ID
    33597
    Jun 2022
    SC
    Rep Power
    Default Lehman Trike Renegade model electraglide rear brakes lock up
    Hi new guy to this interesting forum, l have a problem with my rear brakes locking up after riding for an hour or so, the pedal sticks down n the brakelights on the bike also struggles to move. After l park it the brakes loosen up n pedal goes back to normal. Can anyone help me out with this. Thanks
    15500+ Posts
    User ID
    24367
    Rep Power
    300
    Hi Charlie, Welcome to Trike Talk and your first post
    You could have a compound problem with your brakes
    The first thing is the rear master cylinder could be losing its free travel and not releasing the brakes
    Second, your rear calipers ( I assume you have rear disc brakes) could be sticking and not releasing
    Or if you have a residual check valve on the rear brakes it could be holding pressure on too long
    I would start by bleeding the rear brakes first before replacing any parts, use the correct fluid
    Nuff Said," Were Burnin Daylight, Lets Ride"(Sober 35 years)
    Current ride : 2021 FREEWHEELER M8
    User ID
    33597
    Jun 2022
    SC
    Rep Power
    Default Brake lock up
    I rebuilt the master it was leaking, and l have drum breaks in rear of the trike. So l see from your reply that bleeding the breaks could be part of the issue. I will bleed them after adjusting the brakes. Will let you know thanks for advise
    15500+ Posts
    User ID
    24367
    Rep Power
    300
    Quote Originally Posted by Rio9760 View Post
    After you bleed and test ride, if the brakes hang up, crack the wheel cylinder bleeders, if the wheels free up your master is the cause
    Sometimes rebuilding kits just do not work like they should
    87000+ Posts
    User ID
    6298
    Rep Power
    300
    Charlie.........Welcome To Trike-Talk..........
    User ID
    33597
    Jun 2022
    SC
    Rep Power
    Default Breaks locking
    Hi guys thanks for welcoming me with fantastic info and warmth. I bled the breaks on the trike and low n behold problem solved. I bled them before but apparently not well enough there was plenty of air. Also pedal back to normal. Thanks very much for the insight to do the repairs folks.
    15500+ Posts
    User ID
    24367
    Rep Power
    300
    Thumbs up
    Good deal Charlie, enjoy your rides now that you have the braking under control
  1. Brake rotors for Leaman monarch ll
    By Red trike in forum Lehman Trikes
    Last Post: 07-03-2021, 04:43 PM
  2. Harley Electraglide Standard Returns
    By Jack Klarich in forum *NEW* General Harley Chat
    Last Post: 04-04-2019, 06:24 AM
  3. Bar change electraglide
    By ZED in forum Harley Trike Conversions
    Last Post: 12-15-2013, 06:10 PM
  4. renegade trike
    By bmad in forum General Discussion
    Last Post: 11-25-2010, 08:13 PM
Bookmarks
