AriNV3Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV3AriNVRider Safety Discuss...Maybe silly but serious question, s...
AriNV3cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV13trike ladyNew Member Introduct...New to trike
AriNV13GorillaNew Member Introduct...New to trike
AriNV4GorillaCan Am Spyder Trike...I'm a total newbie ... Is the Spyde...
Grandpot9Papa ZookHonda TrikesFront tire?
Likes Likes:  7
Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
Thread: Rehash after market Motor Trike air bags
  1. #21
    80+ Posts Oldrodder's Avatar
    Mar 2018
    Sudbury, on. Canada
    I finally found the leak! When we drilled & tapped the manifold for mounting holes, we drilled into the compression plugs at the of the manifold. I found the leak by accident! Yesterday, we made another manifold. We drilled the 1/8" air gallery slightly off center to allow room for the mounting holes....worked perfectly! I went for a ride last night with the bags aired up to 15 PSI, I found the ride a little rough. I dropped the pressure to 13 PSI & that was a little better. Out again today and dropped another 2 lbs to 11PSI. I wonder how low I can go without damaging the bags? Any advice anyone???
    TIA.
  2. #22
    350+ Posts 3W-lonerider's Avatar
    Feb 2008
    Shippensburg, Pa
    Quote Originally Posted by Oldrodder View Post
    TIA.
    do you have your shocks set on the lowest setting? i would check that. as far as air pressure in the bags. i ran mine clear down to 7 lb. one time and didn't damage them. but it sounds to me like your shocks are set to stiff.
  3. #23
    200+ Posts
    Dec 2019
    Melbourne Fl USA
    Wow! What a difference the base cycle of the trike kit must make. I am HOPING that the bags are the same. Measurements seemed close when I reached up and checked mine, but that is installed and accuracy may have suffered...
    I cant even put my bags at that low a PSI. The low limit sensor runs the compressor and turns off when there is ~20# in the bags. The bike bottoms out over bumps with this little pressure. Riding alone I set it at 40#. I have considered putting a 40# low limit in it, but have not yet. I bought used, have NO idea if the 20# minimum sensor is a customer added item or from MT's original install.
    With the shocks on #2 of 4, 4 being max lift, I needed near max pressure, 80# or so two up.
    With the shocks on #4, I can now run 60# two up and its the same comfort. Shocks look OK, never had them leak oil.
    I am 225# and Mrs is around 150#.
    Purchased Dec 2019 * 2006 Honda VTX 1800 with solid axle Motortrike Conversion. * Color: Y181P Challenger Brown Metallic * Seats: VTX 1800 Big Boy Seat, Passenger Seat, Driver Backrest and Sissy Bar Pad from Ultimate Seats * Exhaust: SUPER quiet hidden pipes, quad 6" baffles, 51mm DB killers
  1. Replaced Air Bags on Motor Trike
    By paid4c4 in forum Honda Trikes
    Last Post: 05-31-2016, 10:08 PM
  2. Replies: 5
    Last Post: 05-29-2016, 06:34 PM
  3. Replacing Motor Trike Suspension Air Bags ?????
    By Gold Rush in forum Honda Trikes
    Last Post: 04-03-2016, 07:49 AM
  4. Motor trike Air bags
    By burny1970 in forum Motor Trike
    Last Post: 02-07-2010, 12:37 AM
