ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  13
Results 1 to 19 of 19
Thread: Champion driveshaft
    10+ Posts Jester74's Avatar
    Jun 2022
    Mentor, Ohio USA
    Default Champion driveshaft
    Well, I picked up my new to me 2009 gl1800 champion IRS trike on Saturday, rode it home and noticed a thumping on highway. Long story short, I pulled the drive shaft and found the front u joint bad. I called champion trike arizona and they don't have spare driveshafts, all are on backorder and no idea when will come in. He gave me part # of the ujoint, which cannot be serviced...lol. no driveline shops will touch it. So sad she has to sit on lift in garage for an undetermined amount of time. But at least I can get one someday....to the tune of $1200!. Frustrating to have a new ride and not be able to RIDE. does anyone have any ideas on how to repair this driveshaft?
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    What is the part number?
    Contributing Member ROAD DOG's Avatar
    Jan 2009
    MA,
    Quote Originally Posted by Jester74 View Post
    I think I might have one out of my 2008 gl1800 Csc kit ? can you post a picture of the driveshaft ? You may be able to use the front half of mine bring it to a machine shop have it cut and welded,should cost a lot less $ 1200. I will give you the driveshaft you pay shipping, It's one of the mountain man driveshafts that was made to fix the Csc driveshaft problem.
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    If this is a staked u joint even that is no reason a joint cannot be installed
    Staked joints are nothing new, the problem is incompetent mechanics have destroyed drive shafts for lack of training
    If you can get your hands on a replacement joint that has internal spring clips ( snap rings) any competent mechanic can replace these joints
    I could walk you thru how to do it if you like
    Jun 2022
    Mentor, Ohio USA
    They didnt give me a part number for the drive shaft, but they did give me part numbers for the ujoints. the rear, which is serviceable and has a zerk fitting is Neapco 1-0443 and the rear (next to the transmission) which they said is not serviceable is Neapco 1-0170NPL. Which is weird because the replacment is a c clip internal ujoint which by what i can see would then be able to be removed and replaced. I originally thought that it was a "staked" u joint but i cannot see any marks to prove this. tonight i will go and look to see if i can see the c clips. I'm new to this so I apologize for not being more informed.
  6. #6
    Jun 2022
    Mentor, Ohio USA
    Jack,
    Any help would be greatly appreciated. I posted a pic of the u joint and i will be looking tonight to see if its a c clip type. the replacement that champion called out is a c clip type one. I am so confused as to why they would say that this is not replaceable and that a new shaft needs to be ordered. I understand the need to make money but damn. If this is a c-clip, can someone tell me the process to remove and replace? I have never done this before. I'm willing to buy a press from harbor freight to do it right, it would still be a ton cheaper than the $1200 they want for a shaft that they do not have...lolName:  20220703_173342.jpg
  7. #7
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    The picture I am looking at I do not see a staking, it may have what is called crimping, I need to see a clearer picture if you can. So if in fact the replacement joints have infernal clips they are serviceable, it is just a matter of removing the old joints without damaging the shaft. I will be here looking at your thread later today
  8. #8
    Jan 2009
    MA,
    We have a local machine shop that does driveshafts , they press in new u joints , make new driveshafts, you must have a machine shop in your area? Post a picture of the whole driveshaft
  9. #9
    Jun 2022
    Mentor, Ohio USA
    Quote Originally Posted by ROAD DOG View Post
    I will take a pic of the entire shaft when i get home from work, but i called 9 yes 9 driveline shops in Cleveland and all said "nope".
    Jason at champion said that most would not touch it, but he has heard of a few that did do it but did not have names or locations. He did give me the replacement part# for that u-joint, which is a c clip ujoint but the one on the shaft doesn't seem to have the clips, but i cant confirm till i get home. I truly believe they are "crimped" in somehow. I dont mind paying the absurd sum for a new drive shaft, but he doesn't have any at this time and cant tell me when he will get any.
  10. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    By the looks of your shaft I see grinder marks, it must have been rebuilt at one time
    This is typical of a staked or crimped joint
    The stake or crimp will have to be ground off to press the joint out, the new joint will have inside cir clips, I have looked at the joint number you provided and that confirms the cir clips
    Now it is just a matter of removing the old joint
  11. #11
    Jun 2022
    Mentor, Ohio USA
    I'm in luck, the old u joint has c clips so it can be replaced. I have the new one coming in tomorrow, now I just need to be brave enough to tackle it myself or just take to a shop. Thank you all for you insight. I will post up when done this weekend and let everyone know how it turned out...fingers crossed.
    Frustrating that they said it wasn't serviceable, that just isn't correct.
  12. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Good on you, if you want to do it yourself you can rent the tool from some of the local auto parts jobbers, or you can buy one fairly cheap now from Amazon
    I am glad I bought mine when I did and had a warranty, I used it so much I wore out the threaded lead screw
    I have had a Master set for many years way before they became cheap
    If you clean the yoke holes good, use a bit of light lube you should have no problems with the replacement job, I caution anyone from not using hammers to beat them out, it causes damage to the yoke, and is frustrating at best
    Take your time and use the right tools seen below in the link, and good luck
    https://www.amazon.com/U-Joints-Remo...13417926&psc=1
  13. #13
    Jun 2022
    Mentor, Ohio USA
    Great news....after finding out it wasn't a staked part, I took to local driveline shop and they replaced both ujoints and balanced the shaft while I was at work. $98 I can't complain at all. Got home, installed it and she runs like new! I'm a happy happy man. Thanks again to all of you for your help...this site is great!
  14. #14
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    A happy ending Good on you
    Thanks for the update, this may help others
  15. #15
    Jan 2009
    MA,
    You Cant Beat That ! Good Luck
  16. #16
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Default A Thought.....
    Great outcome! Thanks for letting us follow along. Always new things for us to learn. Passing this story on to Champion of Arizona may help enlighten them and others who would contact them with the same type of problem..... Jim
    2005 Premium Mustang Convertible
    2008 Honda GL1800/California Sidecar Trike SOLD
    2014 CanAm Spyder RTL SOLD
    Semper Fi
  17. #17
    20+ Posts JimsGL1800's Avatar
    Jan 2021
    Vicksburg, Michigan USA
    I Replaced both J-joints in my Wing with the Champion IRS kit two years ago. It was easier than replacing the air filter. I purchased both joints from Napa for around 60 bucks for both of them. You should be able to see the part numbers in the photo. I only used a small map gas torch to heat up the yokes to get the caps out easier. These are the old J-joints shown in the photo with it apart.
    There was only 31K miles on the bike, so it was winter and I decided to pull the shaft and replace the joints as long as I was giving the bike a complete PM.
  18. #18
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by JimsGL1800 View Post
    Jim …. Welcome to Trike Talk….👍👍..
    2019 Tri-Glide.......
  19. #19
    Jan 2021
    Thank you. I am looking forward to this great group.
  1. Champion Owners Forum: Post Your Champion Pics
    By Papa Zook in forum Champion Trike
    Last Post: 03-12-2023, 04:52 PM
  2. Champion driveshaft question
    By RoscoeD in forum Honda Trikes
    Last Post: 03-15-2022, 06:17 PM
  3. 2002 GL1800 Champion Driveshaft R&R
    By NMTrikeGL1800 in forum Champion Trike
    Last Post: 03-10-2017, 12:21 AM
  4. Goldwing/Motor Trike driveshaft recall?
    By bumlbe in forum Honda Trikes
    Last Post: 03-21-2012, 10:07 PM
  5. driveshaft
    By sweat12 in forum General Discussion
    Last Post: 02-02-2010, 11:52 AM
